Diatomic molecule at a constant temperature
The discussion centers on determining the time evolution of a diatomic molecule, specifically ##D_{2}##, at a constant temperature of 30K, starting from the initial state ##| \psi (0) \rangle = \frac{1}{\sqrt{26}}(3 | 1,1 \rangle + 4| 7,3 \rangle + | 7,1 \rangle )##. Participants consider using the Hamiltonian for a rotator, expressed as ##H = \frac{L^2}{2I}##, but express uncertainty about how temperature factors into the problem. The canonical formalism suggests that the probability of states should follow the relation ##P \propto e^{-\beta E}##, yet there is confusion about integrating this with the rotator model. Ultimately, it is proposed to treat the molecule as an isolated system at ##t=0##, setting aside temperature considerations for the time being. The focus remains on deriving ##| \psi (t) \rangle ## without explicit environmental coupling.
LCSphysicist
All below...
A diatomic molecule ##D_{2}## in ##30K##, in ##t=0##, is in the state ##| \psi (0) \rangle = \frac{1}{\sqrt{26}}(3 | 1,1 \rangle + 4| 7,3 \rangle + | 7,1 \rangle )##, where the kets denote states ##| l,m \rangle##. Use ##\frac{\hbar}{Ic4\pi}=30.4cm^{-1}##.
Obtain ##| \psi (t) \rangle ##
I think the main point here is to deduce what is the Hamiltonian of the system. But i don't know waht could i use!
First i thought it could be a rotator, so ##H = \frac{L^2}{2I}##. But doing so, i am not sure how the temperatura enters in the problem!
It seems that the probability should follows the canonical formalism, so ##P \propto e^{-\beta E}##, where ##P## is the probability of the state with energy ##E##. But how to connect it to a rotator?
(If the rotator idea is correct)
Without an explicit coupling to the environment, there is no way to solve this for the case of constant temperature.
As the molecule is in a pure state at ##t=0##, I would continue treating it as an isolated system and disregard the mention of temperature.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
