MHB Dice rolls: Counting number of rolls that equals 6 or 7
  • Thread starter Thread starter carl123
    Counting Dice
The discussion revolves around a C++ program that calculates how many times the sum of two rolled dice equals six or seven. The program prompts the user to input the number of rolls, uses random number generation to simulate the dice rolls, and counts occurrences of the sums. Key points include the structure of the program, which utilizes a loop for rolling the dice and conditional statements to tally the results. Additionally, users are encouraged to modify the program to expand its functionality by calculating sums from 2 to 12, implementing a while loop for continuous input until a valid number is provided, and creating a histogram to visually represent the results. The importance of showing attempts at coding challenges is emphasized, as it fosters a collaborative environment for learning and problem-solving.
carl123
The following calculates the number of times the sum of two dice (randomly rolled) equals six or seven.
Code:
#include <iostream>
#include <cstdlib>
using namespace std;
int main(){
int i = 0; // Loop counter iterates numRolls times
int numRolls = 0; // User defined number of rolls
int numSixes = 0; // Tracks number of 6s found
int numSevens = 0; // Tracks number of 7s found
int die1 = 0; // Dice values
int die2 = 0; // Dice values
int rollTotal = 0; // Sum of dice values
cout << "Enter number of rolls: " << endl;
cin >> numRolls;
srand(time(0));
if (numRolls >= 1) {
// Roll dice numRoll times
for (i = 0; i < numRolls; ++i) {
die1 = rand() % 6 + 1;
die2 = rand() % 6 + 1;
rollTotal = die1 + die2;
// Count number of sixs and sevens
if (rollTotal == 6) {
numSixes = numSixes + 1;
else if (rollTotal == 7) {
numSevens = numSevens + 1;
cout << endl << "Roll " << (i + 1) << " is "
<< rollTotal << " (" << die1
<< "+" << die2 << ")";
// Print statistics on dice rolls
cout << endl << endl;
cout << "Dice roll statistics:" << endl;
cout << "6s: " << numSixes << endl;
cout << "7s: " << numSevens << endl;
else {
cout << "Invalid rolls. Try again." << endl;
return 0;
QUESTION
Create different versions of the program that:
1) Calculates the number of times the sum of the randomly rolled dice equals each possible value from 2 to 12.
2) Repeatedly asks the user for the number of times to roll the dice, quitting only when the user-entered number is less than 1. Hint: Use a while loop that will execute as long as numRolls is greater than 1. Be sure to initialize numRolls correctly.
3) Prints a histogram in which the total number of times the dice rolls equals each possible value is displayed by printing a character like * that number of times, as shown below.
Dice roll histogram:
2: ******
3: ****
4: ***
5: ********
6: *******************
7: *************
8: *************
9: **************
10: ***********
11: *****
12: ****
Technology news on Phys.org
Can you show what you'e tried? It's hard to know how to help you when you merely post problems with no effort shown. Our goal is to guide, not do your work. Please add your work to each thread you've posted where you have not already done so, and you will find people will be much more likely to help. :)
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
