Dicontinuity of electric displacement normal to a boundary
In summary, the conversation discusses the use of Maxwell's equations to show that the discontinuity in the electric displacement component normal to a boundary between different media is equal to the free surface charge density on the boundary. The person asking for help has tried using the integral form and integrating over a cylindrical pill box, but is unsure if they can re-use Maxwell's equations as an expression for the electric field. The other person suggests using the equation \oint \vec{D}d\vec{A}=Q_{free} and applying Gauss law with a rectangular pill box in the limit that the height approaches zero.
ailee
1. Hi i need help with this question,
Show, using maxwell's equations as a starting point, that the discontinuity in the component of the electric displacement normal to a boundary between different media is equal to the free surface charge density on a boundary.
i have tried by using the integral form and integrating over a cylindrical pill box (define top lid= A1, bottom lid = A2 cylinder wall = A3) to on the surface (a flat plane with constant charge density)
[tex]\oint E . dA[/tex] = [tex]\int[/tex] E . dA1 + [tex]\int[/tex] E . dA2 + [tex]\int[/tex] E . dA3
last integral is zero as the electric field is perpendicular to the area
but i am not sure as to whether i can re-use maxwell's equations as an expression for the electric field that doesn't seem rigorous and
You should apply this equation: [tex]\oint \vec{D}d\vec{A}=Q_{free}[/tex]. The problem is about electric displacement, right?
Why is the electric field perpendicular to the area? Does the problem state this?
Oh and notice that the height of the cylinder is very small compared to the dimenions of the lid.
Take the displacement above to be D1 and below to be D2 and use Gauss law.
Take a rectangular pill box (that's up to you) and apply Gauss law in the limit that the height of the box approaches zero. (You want the difference in D just above the surface and D just below the surface)
FAQ: Dicontinuity of electric displacement normal to a boundary
What is the definition of "Dicontinuity of electric displacement normal to a boundary"?
The discontinuity of electric displacement normal to a boundary refers to a change in the electric flux across a boundary between two different materials. This change can occur due to differences in the electric permittivity or charge distribution of the materials.
How is the discontinuity of electric displacement normal to a boundary calculated?
The discontinuity of electric displacement normal to a boundary is calculated by taking the difference between the electric displacement values on either side of the boundary. This can be represented mathematically as D2 - D1, where D2 is the electric displacement on one side of the boundary and D1 is the electric displacement on the other side.
What causes a discontinuity of electric displacement normal to a boundary?
A discontinuity of electric displacement normal to a boundary can be caused by a variety of factors, including differences in the electric permittivity of the materials, the presence of free charges on either side of the boundary, or the presence of an electric field that is not perpendicular to the boundary.
What are the implications of a discontinuity of electric displacement normal to a boundary?
The presence of a discontinuity of electric displacement normal to a boundary can have significant implications in the behavior of electric fields and charges at the boundary. It can affect the distribution of electric charges, the strength and direction of electric fields, and the amount of energy stored in the electric field.
How is the discontinuity of electric displacement normal to a boundary related to the continuity equation?
The discontinuity of electric displacement normal to a boundary is directly related to the continuity equation, which states that the net electric flux through a closed surface is equal to the total charge enclosed by that surface. In the case of a boundary between two materials, the continuity equation can be used to calculate the discontinuity of electric displacement across the boundary.
