- #36
Gordon Watson
- 375
JesseM said:Most of this looks good to me, my only question is about why you made it a sum only over identical values of lambda, rather than a double sum over all possible combinations of values. I would guess this is because you want to include the condition that identical detector settings always imply identical results G and G'? This requires that lambda contain no additional information beyond a set of results for every possible measurement setting--if there were two different values of lambda, say i=12 and i=17, that both implied exactly the same set of results for every possible measurement setting, then it could be that the source would occasionally send out a pair with these different values and it wouldn't conflict with the observation that same settings always give same results. But as long as lambda is defined in a minimal way so that different values of lambda always imply different measurement results for some possible pair of detector settings, then it is safe to assume that the source must always send out pairs that both have the same value of lambda, so a single sum like the one you wrote is fine.
OK - thank you -- you just beat me to lodging this refinement -- an old notation of mine that sits better with the use of subscripts yet to come. I found it hard to continue clearly with identical but unrelated subscripts:
[tex]
P''(G, G'|H, a, b') = \sum_{i=1}^N P_3(\lambda_{i}, \lambda'_{i})*P(G|H, a, \lambda_{i})*P'(G'|H, b', \lambda'_{i}).
[/tex]
Trust that's OK.
We next come to defining EPR elements of physical reality.
I will try to get it done during this busy weekend.
Your detailed replies are much appreciated.
JenniT
