Did I make a mistake in this integral?
In summary, the conversation is about a person asking for help in solving an integral involving rotating surfaces. They provide their steps and ask if they have made a mistake. Another person suggests using the disk method and asks if the integrand should be squared. The person clarifies that they are finding surface area and their calculation is correct until a certain point. They mention being too tired to continue and ask for help. Later, they realize their mistake and provide the correct solution.
Dethrone
717
I'm really exhausted mentally, so it'll be really helpful if someone can tell me where I made a mistake. I'm rotating surfaces, and with that, I had to solve this integral:
$$=\pi \int \sqrt{64-3x^2} dx$$
$$=\frac{\pi}{\sqrt{3}} \int \sqrt{\frac{64}{3}-x^2} dx$$
Let $$x = \frac{8}{\sqrt{3}} sin\left({\theta}\right) d\theta$$
$$dx = \frac{8}{\sqrt{3}} cos\left({\theta}\right) d\theta$$
=$$\frac{8\pi }{3} \int \cos^2\left({\theta}\right) (\frac{8}{\sqrt{3}}) d\theta$$
Have I made a mistake already?
As a quick first thought, are you using the disk method, and as such, should the integrand be squared?
I'm calculating surface area, so I'm rotating the line across. The problem basically boils down to what I have above, and I know I'm right up to this point. I know I messed up this integral somehow, but I'm so tired that I don't know how. I've done hundreds of trig. substitution questions, not sure what I'm stuck on this one. My answer is off by a factor of 3, so I want to check my process.
I guess I could type out more steps, but my brain isn't cooperating with me.
After:
$$=\frac{64 \pi}{3\sqrt{3}} \int \frac{1}{2} (1+\cos\left({2\theta}\right) d\theta$$
$$=\frac{64 \pi}{6\sqrt{3}} (\theta + \frac{1}{2} \sin\left({2\theta}\right)) $$
$$=\frac{64 \pi}{6\sqrt{3}} (\theta + \sin\left({\theta}\right)\cos\left({\theta}\right)) $$
The original question is "revolve $\frac{x^2}{16} + \frac{y^2}{4} = 1$ about the x-axis", but I've left out the bounds, etc because my mistake is the integral.
$$S=2 \pi \int_{-4}^{4} y\sqrt{1+(\d{y}{x})^2} \,dx $$
Ah, yes, I see you stated you are finding a surface of rotation...sorry for not reading thoroughly. :D
So, you begin with:
\(\displaystyle I=\pi\int\sqrt{64-3x^2}\,dx\)
I would let:
\(\displaystyle x=\frac{8}{\sqrt{3}}\sin(\theta)\,\therefore\,dx=\frac{8}{\sqrt{3}}\cos(\theta)\,d\theta\)
And so we now have:
\(\displaystyle I=\frac{64\pi}{\sqrt{3}}\int\cos^2(\theta)\,d\theta\)
This is indeed 3 times greater than what you stated. Do you see your error in the first step you made in the first post?
My head is so fried right now, but I found my mistake.
It should be this:
$$\sqrt{3(\frac{64}{3}-x^2})=\sqrt{3}\sqrt{\frac{64}{3}-x^2}$$
I was trying to factor out 3, but instead, I did something quite careless...(Rofl) I knew it was a dumb mistake from the start...(Crying)
FAQ: Did I make a mistake in this integral?
1. What is integration error check?
Integration error check is a process used in scientific research to assess the accuracy and reliability of data integration from multiple sources. It involves comparing the data from different sources and identifying any discrepancies or errors that may have occurred during the integration process.
2. Why is integration error check important?
Integration error check is important because it helps to ensure the validity and integrity of research data. By identifying and correcting errors, researchers can have confidence in the accuracy of their results and conclusions.
3. How is integration error check performed?
Integration error check is typically performed using specialized software or statistical tools. The process involves comparing data from different sources and identifying any outliers or discrepancies. These errors can then be further investigated and corrected if necessary.
4. What are the potential sources of integration error?
Integration errors can occur due to a variety of factors, such as human error, technical issues, or differences in data collection methods. They can also be caused by data transfer or conversion processes, as well as inconsistencies in data formatting or labeling.
5. Can integration error check be automated?
Yes, integration error check can be automated using specialized software or scripts. This can help to streamline the process and reduce the potential for human error. However, it is still important for researchers to carefully review and interpret the results of the automated error check to ensure the accuracy of the data.
