MHB Did I misinterpret the sign attached to a term when factoring?
The discussion revolves around the correct factoring of the expression xy+x-2y-2. The original attempt resulted in x(y+1)-2(y-1), which was incorrect due to a misunderstanding of sign when factoring out -2. The correct factorization is x(y+1)-2(y+1), leading to (x-2)(y+1). The key takeaway is that when factoring out a negative, the signs within the parentheses must change, highlighting the importance of careful sign management in algebraic manipulation. Understanding these nuances is crucial for accurate factoring in future problems.
find_the_fun
I wanted to factor [math]xy+x-2y-2[/math]
I got [math]x(y+1)-2(y-1)[/math] and got stuck
I tried somethings out and noticed [math](x-2)(y+1)=xy+x-2y-2[/math] so how come I did get stuck? Did I extract the [math]2[/math] incorrectly with the sign? For example should I have interpreted it at [math]-2y-2[/math] not [math]2y-2[/math]?
Mathematics news on Phys.org
Yes, you simply factored incorrectly.
[math]xy+x-2y-2=x(y+1)-2(y+1)=(x-2)(y+1)[/math]
When you factor a negative factor from a group of terms, the signs of everything within the resulting parentheses must change.
But [math]2y-2[/math] can be factored to [math]2(y-1)[/math]. Since [math]2y-2[/math] appears in the equation can't we say [math]...-(2y-2)=...-(2(y-1))[/math]?
It is $-2y-2$ that appears in the expression...and both terms have $-2$ as a factor. :D
That's the point. [math]2y-2[/math] does not appear in the equation.
You can read the equation as:
$$xy+x−2y−2 = xy+x+(−2)y+(−2)$$
As you can see $(−2)y+(−2)$ is definitely different from $2y-2$.
From here we can get to:
$$xy+x+(−2)y+(−2) = x(y+1)+(−2)(y+1)$$
Which can also be written as:
$$x(y+1)−2(y+1)$$
I guess I see what I did wrong, I did something like, took a -2 inserted a bracket and pretend it was positive. I try to understand exactly what went wrong in hopes of not making the same mistake again.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
