Did my textbook make a mistake when writing these units?
In summary, the text questions whether the textbook has inaccuracies in its representation of certain units, suggesting that there may be discrepancies or errors in the unit conversions or definitions provided. The inquiry implies a need for clarification and verification of the textbook's content.
mymodded
29
A motor has a single loop inside a magnetic field with magnitude 0.870T. If the area of the loop is 300 cm^2 , find the maximum angular speed possible for this motor when connected to a source of emf providing 170V
$$\Delta V_{ind} = -\frac{d\phi _B}{dt} = \omega BA \sin(\theta ),
\omega = 2\pi f$$
Sorry if there are mistakes regarding the post itself, this is my first time posting.
This an easy problem to solve, but this isn't what I'm looking for, but first of all, you can plug in the values and solve for ##\omega##, and it equals ##\frac{170 V}{0.87 T(0.0300 m^2)}## = 6513 Hz, my question is, is the unit correct here? I thought that it should be measured in rad/s, but the answer guide put in Hz, which is weird, because Hz here means revolutions/second, which is obviously different from rad/s (by a factor of 2 ##\pi##), also, ##\omega## = 2##\pi##f where f is measured in Hz or 1/s (or more specifically, rev/s) and multiplying the number of revolutions by 2##\pi## gives you the number of radians. So did the textbook write it incorrectly?
mymodded said:
Homework Statement: A motor has a single loop inside a magnetic field with magnitude 0.870T. If the area of the loop is 300 cm^2 , find the maximum angular speed possible for this motor when connected to a source of emf providing 170V
Relevant Equations: $$\Delta V_{ind} = -\frac{d\phi _B}{dt} = \omega BA \sin(\theta ),
\omega = 2\pi f$$
Hi @mymodded and welcome to PF.
You are correct - the value should be in rad/s. Occasionally 'official' answers are wrong.
Also, the answer should be rounded to a suitable number of significant figures. I'd say 6500 rad/s is an appropriate answer.
Likes mymodded
Radians per second and hertz have the same dimension. They are interchangeable. This is a source of great confusion and much has been written about the fact that the radian is a unit but not a dimension.
If you look up the definition of the radian you find that it is dimensionless, it's a ratio of lengths.
As a student you have to get used to the fact that the radian can pop into and out of your calculations.
Take for example the relation ##v=r\omega##. Calculate the value of ##v## if ##r=2\ \mathrm{m}## and ##\omega=3\ \mathrm{rad/s}##. The value of ##v## is ##6\ \mathrm{m/s}##.
Note: Edited on 29 March to fix the mistake I made, discussed in Post #5.
Just to ensure that the OP is not confused, we need to be clear that, as units, rad/s and Hz, are not freely interchangeable. A conversion factor is needed. 1Hz = ##2\pi## rad/s.
The OP asked:
mymodded said:
and it equals = 6513 Hz, my question is, is the unit correct here?
So the answer to the OP's question is: no - the unit is wrong; the correct answer is 6513rad/s (ignoring the inappropriate number of significant figures).
My mistake. You are correct. Even though they have the same dimension they are not the same unit, and thus are not interchangeable. I need to be more careful.
Likes Steve4Physics and haruspex
Thanks a lot
Likes Steve4Physics
FAQ: Did my textbook make a mistake when writing these units?
1. What should I do if I suspect a mistake in the units provided in my textbook?
If you suspect a mistake in the units, the first step is to cross-reference the information with other reliable sources, such as academic journals, reputable websites, or other textbooks on the same subject. If the discrepancy persists, consider discussing it with your instructor or a knowledgeable peer to gain further insight.
2. How can I verify if the units in my textbook are correct?
You can verify the units by checking standard reference materials, such as the International System of Units (SI) or other authoritative scientific resources. Additionally, you can consult online databases, educational websites, or professional organizations related to the subject matter for confirmation.
3. Are there common types of mistakes in units that textbooks make?
4. How does a mistake in units affect scientific understanding?
A mistake in units can lead to significant misunderstandings or miscalculations in scientific work. It can affect experimental results, data interpretation, and the overall credibility of the findings. Therefore, it's crucial to ensure that units are accurate and consistent throughout any scientific study.
5. What resources can help me clarify unit conversions and standards?
There are several resources available for clarifying unit conversions and standards, including online conversion calculators, educational websites like Khan Academy or Coursera, and scientific reference books. Additionally, apps designed for scientific calculations can provide quick and accurate conversions.
