Did you know that a right triangle can be found using only one side?
In summary: The formula c^2 = cx + cy can be used to find these values. However, it is also possible for the other sides to be 1 and ##2\sqrt 6##. The formula does not provide enough information to determine the exact values of the other sides. This method may be interesting to explore, but it does not contradict or replace the traditional Pythagorean formula for finding right triangles.
  • #36
Borek said:
OK, so if you are right, you will have no problem solving my problem.
I have a triangle with hypotenuse length equal to 10. Give me the other two sides of the triangle I have on mind.
Frankly how do you know that your other two sides are correct? Show me your design work since you have admitted having a solution on your mind. Did you use any of my methods or not?.
Mathematics news on Phys.org
  • #37
Let me ask you this instead. At what point do you want your hypotenuse separated into x and y?
  • #38
I cannot believe people are giving you so much greif for this Crazy Horse. As what you found (while not a new rule) is a simple beautiful association.
The mathematical law is of course priceless (although already discovred) but great credit to you for rediscovering.
Here I shall explain. If you are given a hypotenus, and you "assume that you have a right angle" (this part is key) these are all the clues you need for a variant of the proof tequnique known as (Side Angle Side/ Side Angle Angle). Its obvious that for a given hypotenus there can only be one right side angle with respect to the hypotenus.
Briefely put the tecnique invovles alwasy constructing a trialnge of of a line (assuming its the hypotenus) with an angle of 90 degrees. There is only one way this can possibly be done which is why crazy horse alwasy gets the right results.
I would consider this more a tecnique (an extremely usefull and overlooked); but it really isn't a new way or another proof etc; just a very intelligent and well posed method by carefully using the asumptions you can give a problem (the 90 degree ange) and hypotenus length to incredibly simplify a problem; basically what heavyside did to maxwell.
Great Job Crazy Horse if you have any other great ideas let me know I always give good open minded scientific feedback :D
  • #39
okay x = 3 and it is 1/5th of the line what are the other two sides? boo who I don't have enough information?
but yes you do!
Yes of course you can calculate it, and that is nothing new.
What is your answer to the question?
c=15
a=sqrt(cx)=sqrt(45)
b=sqrt(c(c-x))=sqrt(180)
Personally I feel that you still don't have enough information if all you are limited to Pythagoras theorem or the law of sine's!
You can apply Pythagoras twice, or use a formula which is the result of that application. It is called "Kathetensatz" (literally: "theorem of the cathetus") in German, I don't know how it is called in English.
  • #40
Closed for moderation.
  • #41
Once we finish I will gladly give you my result and you will be able to check by yourself, using Pythagorean theorem, that they are correct.
I am not going to show them - you said you can calculate just by knowing hypotenuse, it is time that you prove you can do it.
If you need more information, it means you can't solve the problem.
