Dielectric Antennae: Energy Feed-In/Take-Out Explained
In summary, an antenna consists of a Feed point and a radiating structure. The Feed point launches a wave onto the radiating structure. The radiating structure may be a wire, a dish, or a dielectric resonator.
qnach said:
But I cannot figure out where does the energy feed-in or take-out from the antenna?
The dielectric antenna must be supplied with RF energy by a transmission line or waveguide.
The RF energy may be generated within the dielectric material by an RF amplifier on the ground-plane.
I think this is the same as other antenna. Normal antenna also need to be supplied with electric wire.
The problem is WHERE is the opening?
For a linear antenna, we normally cut in the middle to feed the energy.
For a circular antenna, we cut anywhere.
But the only shape of dielectric antenna I have ever seen is cylindrical shell (why?) so...
where should I cut?
It sounds like a traditional metal microwave horn or metal waveguide is used to inject the microwaves into the ceramic resonator:
Radio waves are introduced into the inside of the resonator material from the transmitter circuit
This looks like a useful web page:
http://www.ijser.org/paper/Design-o...hed-Characteristics-for-UWB-applications.html
The dielectric antenna is often a resonator having high Q. The induction fields extend outside the material to some extent and energy is coupled into it by a probe. Due to the high Q, the reactive fields are very strong, so very little coupling will be required.
Another class of dielectric antenna may consist of a tapered rod, obtaining directivity by traveling wave action. In this case the Q is low and energy will be coupled by a structure which is larger than for the high Q variety, resembling a conventional metallic antenna located at one end.
Notice that a dielectric contains charges which can be made to accelerate, and hence it will radiate. By contrast, a capacitor having wide spacing but filled with a vacuum will not.
conventional ante,
where should I cut?
One way to describe how an antenna works is that the Feed point (where the power is connected) launches a wave onto the radiating structure. In the case of a straight wire antenna, the wave passes along the wire and is reflected at the ends to form a standing wave along the wire. A directional wire antenna uses several wires to produce a wave in a preferred direction. A dish (parabolic) antenna focusses a broad beam from the drive point (waveguide or dipole) to point in the wanted direction.
In a dielectric antenna, the wave is launched using a capacitative coupling and directivity is achieved in a similar way to how a lens works - by refraction at a curved surface. I only know of dielectric antennae being used at high radio frequencies (microwave wavelengths).
Have you googled "dielectric antennae' Images? Pictures are useful for this sort of subject.
Yes, I googled and find some useful picture, such as
http://file.scirp.org/Html/2-9801252/34094843-70a9-4b80-8de7-9f897d1ebfc0.jpg
Perhaps, I never seen one, the description sounds strange for me...
That picture is strange too. They usually said it had a ground metal plate? But the cylinder had no opening?
Since the antenna is made of dielectric, why is there still need for a metallic plate?
There has to be some way of applying an EM field to the dielectric so that the waves through the antenna are directed or focussed in some way. The "plate" will possibly be inside the dielectric itself and launches the wave into the shaped dielectric.
There are many designs for dielectric antennae so, as with 'metal' antennae, it is not possible to specify much about the feeding arrangement. Some dielectric antennae behave just like an optical lens - in the same way that a reflecting dish (e.g. Newtonian Telescope) does effectively the same thing as the lens in a refracting telescope.
Did you look in Google Images yet?
Yes.
At present,
I am looking for analytic solution of a ring (shell) shape (center feed?) DRA. Do you have one? Any reference?
qnach said:
Yes.
At present,
Sorry. I have only read about them in the past.
Is it true that dielectric antenna works more or less like acoustic resonator?
It is a resonator to my understanding, different from metallic antenna.
Please link to or post a sketch of the shape you want. Rings and shells come in many shapes.
Yes, you can think of it that way, but I doubt that it will make it easier to understand. You might do better thinking of a DRA as a glass bead or lens with dimensions of only a few optical wavelengths.
Baluncore said:
Please link to or post a sketch of the shape you want. Rings and shells come in many shapes.Yes, you can think of it that way, but I doubt that it will make it easier to understand. You might do better thinking of a DRA as a glass bead or lens with dimensions of only a few optical wavelengths.
For a man has background in acoustics and played music instrument an acoustic resonator is indeed much easier.
However, I think the physics inside is indeed a resonator, quite different from lens, other metallic antenna, and glass beeds...
You put a fork on a box then it is louder...I guess that is the way it is woking.
You seem to have got this all wrong (which is what can happen when people jump into a very complex subject without the basics). The purpose of a resonator in any antenna is to provide matching between the transmitter and the radiating structure. Most acoustic radiators are also matched to the source and it is common to use a resonator to achieve this (A Wooffer for instance, uses a Helmholz type resonator). But there are still non-resonators in acoustics - think of the Horn structure; that has no resonance.
Most (but not all) metallic antennae use resonance. Take the humble dipole, for instance, which is usually (but not always) chosen to have a length that resonates. A dielectric antenna is used to achieve directivity and requires an interface between the metal circuitry and the dielectric medium and that can be resonant. Can any members think of a dielectric antenna that's used for a wide / omni pattern?
A glass bead or lens has a reflection coefficient at the surface that results in radiation of the transmitted component from over the entire dielectric surface, while the internally reflected component provides the internal low-loss resonance.
An acoustic resonator behaves more like holes cut in a waveguide stub. Radiation is only released from discrete ports in the resonator wall. If you want to study perforated waveguide arrays, then you can model them as acoustic resonators. But that will not help you understand dielectric resonator antennas.
Can any members think of a dielectric antenna that's used for a wide / omni pattern?[/QUOTE]
In the case of some microstrip antennas, there may be radiation from the dielectric layer.
Further, when the transmitter is switched on, the resonant structure takes some time to fill with energy. During normal operation it is not doing any radiating. Then, after switch-off, it continues to supply energy to the radiating structure for another short period of time. The stored energy provides the induction fields that are seen around an antenna. The same happens with acoustic instruments such as a guitar. The "box" does not amplify the sound, it is just the radiating structure. Energy is put into the string by plucking and then it slowly empties again into the wooden radiating structure.
Likes sophiecentaur
So,...what is wrong (your very first sentence)?
Actually, I think it's me that's got it wrong, sorry. (fools rush in) But is the "resonance" the relevant thing or just the standing wave?
There are a number of wire antenna designs that use high order modes on a wire that's several wavelengths long, to increase directivity. The standing waves are there, whatever the length of the wire but the input matching can improve efficiency.
The 5/8 wavelength vertical monopole, beloved of radio amateurs, has significantly higher vertical gain than a simple 1/4 wavelength whip. It's the equivalent of a 5/4 wavelength dipole. I can see that there is a lot to be said for using standing waves in a dielectric dome / ring because it has circular symmetry. The metallic equivalent would presumably be a disc or dish reflector where there are images of the drive over the area of the reflector. I like the 2/3 size advantage for the dielectric system.
I think there must be a limit to the achievable aperture with such antennae due to losses over several wavelengths of path in the dielectric. I remember the problems with flat plate printed circuit slot arrays limited the useable aperture.
You seems to write this paragraph with some books? What is that? Wow,5/8 wavelength vertical monopole...
I think you were right in the first place. If you consider a wire with a certain current flowing, then the radiation will be the same however you produce that current. For instance, you can either use transmission line resonance in the wire or terminate it with a resistor. The latter method is wasteful but radiates a very similar field for each Amp-metre.
Likes sophiecentaur
IT's the sort of antenna that suits 2m comms bands. You put it on a ground plane and mount it up on a chimney. I have even made one which worked well. It also happens to be fairly non-critical to match to a 50Ω feeder. Just google it. There is plenty of stuff written about practical applications.
But your application is for a very different wavelength.
Is it possible to have an antenna of such shape?
The left is the top view the right is the side view.
Why is such design?
What is the scale ?
What is the wavelength ?
What do the colours represent ?
Are you considering photon emission from a molecule ?
Baluncore said:
What is the scale ?
about 2 cm
microwave region
I simply arbitrarily pick a picture from google therefore it has colour
Here is a black and white picture attached.
Is there a loop antenna of such shape? Is there any benefit of such shape?
I have ever seen antnna of square shape as attached. But I do not know what will the effect if
I change the square into a circle?
Are you saying that you think that complex biomolecules are acting as antennas?
I have ever seen antnna of square shape as attached. But I do not know what will the effect if I change the square into a circle?
The top two pictures are typical square loop antenna arrays. You can make them out of circles if you want, but they will have slightly different radiation characteristics.
I have no idea what the bottom scrolls are or why you might consider using them as antennas. Are they made out of metal or jello? Anything will radiate if you can find a way to drive it. You seem to have no experience with antennas, nor any idea as to how or why they might work. I get the feeling that you are deliberately wasting our time.
When you post pictures on PF you should give a reference or the web link to the original. That way we can work out what their relevance might be. Without a web link to the original they are not only usless but may be plagiarism and lead to a breach of copyright.
I had experience using the square loop antenna for my home DVBT. Each side of the square is 12.6cm.
I remember the gue told me that antenna said the turn of each side will cause some phase change.
Will those square loop antenna will function better than simple loop antenna?
Sure, anything can be used made into an antenna, the problem is whether will it radiate good (radiation pattern ).
I had experience with many antenna, but not too much.
I never waste any time of an antenna expert, but if I meet a potitician I have to talk about politics.
Related to Dielectric Antennae: Energy Feed-In/Take-Out Explained
1. What is a dielectric antenna?
A dielectric antenna is a type of antenna that uses a dielectric material, such as plastic or ceramic, to transmit and receive electromagnetic waves. It is often used in high-frequency applications, such as satellite communication and radar systems.
2. How does a dielectric antenna work?
A dielectric antenna works by converting electrical energy into electromagnetic waves and vice versa. The dielectric material acts as an insulator, allowing the antenna to efficiently transmit and receive signals without losing energy.
3. What is energy feed-in/take-out in dielectric antennas?
Energy feed-in/take-out refers to the transfer of energy between the antenna and the surrounding environment. In a dielectric antenna, energy is fed into the antenna through an electrical source and is then radiated out as electromagnetic waves. Similarly, when electromagnetic waves are received by the antenna, they are converted back into electrical energy.
4. What are the advantages of using dielectric antennas?
Dielectric antennas have several advantages over other types of antennas, including a smaller size, lighter weight, and higher efficiency. They are also less prone to interference and can operate in a wider frequency range.
5. What are some applications of dielectric antennas?
Dielectric antennas have a wide range of applications, including satellite communication, radar systems, wireless power transfer, and medical imaging. They are also used in consumer electronics, such as cell phones and Wi-Fi routers.
  • Electrical Engineering
