Dielectric objects in electric field
In summary: A metal sphere with an insulating coating is a Faraday cage, because it completely blocks electric and magnetic fields.
st_01
Hello,
This is simple question, but I didnt find the clear answer e.g. on the web pages:
How Faraday cage works in electric field is clear.
1. The metal blown sphere = faraday cage in electric field - inside the sphere is not electric field.
2. But how is it when the blown sphere is made from dielectric material ?Is there inside the sphere electric field or not?
Thanks
st_01
I am not aware that it is possible to make a Faraday cage out of purely dielectric, non-conducting material. You need free or semi-free charges in a material in order to move around and cancel out the incident waves. You could make an electromagnetic shield out of dielectric if it is highly absorbent at a frequency of interest (a cardboard box is a shield to visible light) but that would not really be a Faraday cage. A Faraday cage blocks almost all frequencies of incident electromagnetic waves, whereas a plastic box painted black will not.
Idea is to induce the surrounding emf back to electrical current and send it to ground. Denser the grid higher the performance. You can't make a Faraday cage out of pure dielectric, more you get close to perfect conductivity (not super conductivity) more you eliminate emf.
Faraday cage doesn't necessarily block all spectrum, it will depend on the specifications and the application. Cage sizes, grid mesh sizes, material conductivity.
Hi,
Forget the faraday cage.
The basic question is: The blown sphere from dielectric (isolant) material is in electrostatic field (no electromagnetic waves).Is there inside the sphere electrostatic field or not?
There is.
Yes, I agree with you (y33t), but how is it in situation:
We have for example positive charged sphere with cavity made of isulation material.
Is there electric field in the cavity?
Yes there is but less then completely insulating surface case. Insulating surface will cause leakage which will end up static fields in the sphere (assuming electrostatic condition). If you need to know what will 'exactly' happen, youneed to simulate the system. Solution will require sphere's dispersion parameters and geometrical definition and surrounding field vectors/sources. Result will be electric and magnetic field components in/on/out of the sphere.
st_01 said:
Hi,
Yes. Take a look at this problem involving a http://faculty.uml.edu/cbaird/all_homework_solutions/Jackson_4_8.pdf" .
By the way, an "insulator" refers to the fact that a material insulates against electric current (e.g. keeps electricity in wires), not that it insulates against fields.
FAQ: Dielectric objects in electric field
What is a dielectric object in an electric field?
A dielectric object is a material that does not conduct electricity, such as rubber or plastic. When placed in an electric field, the electrons in the material will shift slightly, creating a polarization effect.
How does a dielectric object affect an electric field?
A dielectric object can alter the strength and direction of an electric field by changing the electric potential and storing electrical energy. This is known as the dielectric constant or permittivity of the material.
Can a dielectric object become charged in an electric field?
Yes, when a dielectric object is placed in an electric field, the electrons in the material may shift, causing one side of the object to become positively charged and the other side to become negatively charged. This is known as dielectric polarization.
How does the shape of a dielectric object affect its behavior in an electric field?
The shape of a dielectric object can affect its ability to store electrical energy. For example, a spherical dielectric object will have a higher capacitance (ability to store charge) than a flat, disc-shaped dielectric object of the same size.
What is the difference between a conductor and a dielectric in an electric field?
A conductor is a material that allows electrons to flow freely, while a dielectric is a material that does not allow electrons to flow. This leads to different behaviors in an electric field, with conductors experiencing a flow of current and dielectrics experiencing a polarization effect.
