Dielectrics and Capacitors, Very confused.
In summary, the question asks about the change in charge on the positive plate of a parallel plate capacitor when a Teflon slab is inserted between the plates, completely filling the air gap. The capacitance formulas Q=CV, C=eA/d, and C=keA/d are provided. The given values are C=25x10^-12F, ktef=2.0, permittivity constant=8.85x10^-12, and v=100v. To find the change in charge, we need to calculate the two capacitances before and after the Teflon is inserted using the formula C=keA/d and then use Q=CV to find the charge, and finally subtract the two charges
ryan8642
24
A 25pF parallel plate capacitor with an air gap b/w the plates is connected to a 100v battery. A Teflon slab is then inserted b/w the plates and completely fills the gap. What is the change in charge on the positive plate when the Teflon is inserted?
Q=CV
C=eA/d
C=keA/d
e=permittivity constant
I am very confused and don't know what to do, none of the formulas make sense for this question... :(
But
C=25x10^-12F
Kteflon=3.0
v=100v
what do i do? soo confused
find the two capacitances after and before the plate is inserted
find the charge using Q=CV as you wrote
then just subtract the charge!
i don't get it, how do i find the capacitance when the teflon is inserted? do i just multiply the C (up there) by 2.0?
ktef should be 2.0 not 3.0
Yes. By 2.0
As a scientist, it is important to approach problems with a clear and logical thought process. In this case, we are dealing with dielectrics and capacitors, which are commonly used in electronic circuits. A capacitor is a device that stores electrical charge, and dielectrics are insulating materials that are placed between the plates of a capacitor to increase its capacitance.
To solve this problem, we need to use the equation Q=CV, where Q is the charge on the capacitor, C is the capacitance, and V is the voltage. We also need to consider the equation for capacitance of a parallel plate capacitor, which is C=eA/d, where e is the permittivity constant, A is the area of the plates, and d is the distance between the plates.
In this problem, we are given the capacitance (C=25pF) and the voltage (V=100V) of the capacitor. We also know that the Teflon slab has been inserted between the plates, completely filling the gap. This means that the distance between the plates has decreased from its original value, and the area of the plates remains the same.
To find the new capacitance, we can use the equation C=keA/d, where k is the dielectric constant of the material. In this case, the dielectric constant of Teflon is given as 3.0. Therefore, the new capacitance (C') can be calculated as C'=3.0(25pF)=75pF.
Now, using the equation Q=CV, we can find the new charge on the capacitor when the Teflon is inserted. The charge on the positive plate will be equal to the charge on the negative plate, so we can simply divide the total charge by 2. Therefore, the new charge on the positive plate (Q') can be calculated as Q'=75pF(100V)/2=3750pC.
In summary, when the Teflon slab is inserted between the plates, the charge on the positive plate increases to 3750pC. This is because the dielectric material increases the capacitance of the capacitor, allowing it to store more charge at the same voltage. I hope this explanation helps to clarify the problem and the use of the equations involved.
FAQ: Dielectrics and Capacitors, Very confused.
What is a dielectric material?
A dielectric material is a type of insulating material that does not conduct electricity. It is commonly used in capacitors to store and release electrical energy.
How do dielectrics affect the capacitance of a capacitor?
Dielectrics increase the capacitance of a capacitor by reducing the electric field between the plates, allowing for more charge to be stored on the plates.
What is the difference between a dielectric and an insulator?
A dielectric is a type of insulating material, but not all insulators are dielectrics. Dielectrics are specifically used in capacitors to increase capacitance, while insulators are used to prevent the flow of electricity.
Can dielectric materials conduct electricity?
No, dielectric materials are specifically designed to be non-conductive and prevent the flow of electricity.
How do you choose the right dielectric material for a capacitor?
The choice of dielectric material depends on the specific application and the desired properties of the capacitor. Factors to consider include dielectric constant, breakdown strength, and temperature stability.
