Dielectrics scattering electromagnetic waves
In summary, the device is an active flat cavity with two outer mirrors and a central dielectric that reflects the waves. The resonance is tuned by angle and is dependent on the dimensions of the waveguide structure.
JerseyDevil
Hello everyone,
First and foremost I would like to see if everyone's having a good day? (assuming you respond yes) Awsome! Secondly I was hoping someone would be able to help me understand how dielectrics work.
I don't need to know everything about dielectrics. I only need to know how they affect electromagnetic waves passing through them. More specifically how they would affect the amplitude of an RF signal having a frequency of anywhere between 10 MHz to 100 GHz and an unmodulated amplitude.
The reason I would like to know specifically about dielectrics is because I read the following from a patent description which can be found here http://www.freepatentsonline.com/5230029.html" :
"The results of non-normal plane-wave scattering from a planar three-layer guiding structure as illustrated in FIG. 1 in which the central dielectric film or layer is active are described." "A fine-grained scan of the plane-wave incidence angle, has revealed the existence of narrow discrete angles where large amplitude scattering resonance is obtained. Enhancements in the scattered field intensities on the order of 100 have been observed using active films 80 as thin as 6 microns."
From what I understand this means that this dielectric film 80 reflects an electromagnetic wave which scatters the amplitude of the incedent wave.
Ofcourse I could be terribly wrong seeing as how this is all very confusing to me, So if anyone out there knows what's really going, could you please either tell me "no, you're not right" or instead tell me "yes, you're correct" and then explain how the dielectric does this.
Sorry if this was all very confusing, but any help would be most appreciated.
ugh... I'd forgotten how much I don't like patents: they usually take for ever to say nothing.
Anyway... I don't really get your question, but it seems that the device is nothing more than an active flat cavity. The two outer layers act as cavity mirrors and the central dielectric is the gain medium. The resonance is tuned by angle. I would suggest you read the wikipedia entry on lasers and perhaps thin film interference.
The properties of the devices/structures the patent depend primarily on the dimensions of the waveguide structure, not so much the dielectric itself.
What the patent authors are doing are making waveguides with what are called leaky modes. These modes are slightly different to guided modes in that they decay slightly with length (hence the name), but still have a well defined field shape (as opposed to radiation modes). Importantly, leaky modes, have well defined propagation constants, which means that the energy that leaks out of these modes at well defined angles.
Claude.
Related to Dielectrics scattering electromagnetic waves
1. What is the role of dielectrics in scattering electromagnetic waves?
Dielectrics are materials that do not conduct electricity, such as insulators. When electromagnetic waves encounter a dielectric material, they cause the electrons within the material to move and vibrate. This movement of electrons creates an electromagnetic field that interacts with the incoming wave, causing it to scatter in different directions.
2. How does the scattering of electromagnetic waves by dielectrics affect communication signals?
The scattering of electromagnetic waves by dielectrics can cause interference and disruptions in communication signals. This is because the scattered waves can interfere with the original signal, leading to a decrease in signal strength and quality. This is why dielectric materials are often used to block or shield certain frequencies in electronic devices.
3. What factors influence the amount of scattering of electromagnetic waves by dielectrics?
The amount of scattering of electromagnetic waves by dielectrics depends on several factors, including the type of dielectric material, its thickness, and the frequency of the incoming wave. Generally, materials with higher dielectric constants and higher densities will cause more scattering of electromagnetic waves.
4. Can the scattering of electromagnetic waves by dielectrics be controlled or manipulated?
Yes, the scattering of electromagnetic waves by dielectrics can be controlled and manipulated. This can be achieved by changing the properties of the dielectric material, such as its density or composition, or by using specialized coatings or structures to alter the direction and intensity of the scattered waves.
5. How is the scattering of electromagnetic waves by dielectrics used in practical applications?
The scattering of electromagnetic waves by dielectrics has many practical applications. It is used in radar technology to detect and track objects, in satellite communication systems to transmit and receive signals, and in medical imaging techniques such as MRI. It is also used in everyday devices, such as cell phones and WiFi routers, to transmit and receive signals without interference from other electromagnetic sources.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
