Diff EQ Direction field asymptotes
In summary, the student is trying to figure out how to find the direction field for the differential equation y'=1-y/x. They know that when y=x, the slope will be zero, and that when x approaches zero, the slope approaches -/+ infinity. They are also aware that y'=1-y/x is the same as y'= (x- y)/x and that y=ax will be an asyptote if a= 1- a or a= 1/2.
ElijahRockers
Draw the direction field for the differential equation y'=1-y/x
Ok well, drawing the direction field is not an issue because I have a grapher, and I get the basic of how to draw simple direction fields. So to start, I know that whenever y=x, the slope will be zero, so every point on the line y=x has slope zero. I can test points around that to get a general idea of what's happening. Also I know when x approaches zero, the slope approached -/+ infinity depending on the sign of y.
So far so good...
But the other asymptote besides x=0 also seems to be a line y=x/2. How do I conclude that analytically from y'=1-y/x ? I'm sure it's something simple...
Thanks.
If y= ax is an asymptote then points on that line must be mapped to other points of that line. y'= 1- y/x is the same as y'= (x- y)/x and if y= ax, that becomes a= y'= (x-ax)/x= 1- a. y= ax will be an asyptote if a= 1- a or a= 1/2. That is, the asymptote is y= (1/2)x as you say.
yikes, ok i see how you worked it out, i don't see any voodoo but it certainly blew my mind when you went from y=ax to y'=a, and subsequently to a=1-a...
ok, so I'm not quite clear on what you mean by If y= ax is an asymptote then points on that line must be mapped to other points of that line.
he probably won't make us do very complicated ones, but i am interested on how i could translate this technique (if possible) into finding asymptotes described by polynomials, for instance?
thanks for all your help on the problem, if you know of any resources that discuss drawing direction fields in more detail i would be interested... every example i see is usually a simple one with only horizontal asymptotes
thanks again
FAQ: Diff EQ Direction field asymptotes
What is a direction field in differential equations?
A direction field in differential equations is a graphical representation of the slope or direction of a solution curve at different points on a graph. It helps to visualize the behavior of a solution curve and understand the relationship between the dependent and independent variables.
How are direction fields useful in solving differential equations?
Direction fields provide a visual aid in understanding the behavior of a solution curve and can help in estimating the shape and direction of the curve at different points. It also aids in identifying critical points, such as asymptotes, and understanding the overall behavior of the solution.
What are asymptotes in a direction field?
Asymptotes in a direction field are lines or curves that a solution curve approaches but never touches. They can be horizontal, vertical, or oblique and can help in understanding the long-term behavior of a solution.
How can I determine the asymptotes in a direction field?
To determine the asymptotes in a direction field, you can find the values of the independent variable where the slope of the solution curve approaches infinity or zero. These points will correspond to the vertical or horizontal asymptotes, respectively.
Can direction fields have multiple asymptotes?
Yes, direction fields can have multiple asymptotes, depending on the behavior of the solution curve. For example, a solution curve may have both a horizontal and a vertical asymptote, indicating different long-term behaviors in different directions.
