A Diffeo-invariant action for a matter covector field
ergospherical
Education Advisor
Insights Author
I just need a hint to get started, and then I reckon the rest will follow...
We consider a theory where matter is a covector field ##\omega_a## which is described by a diffeomorphism-invariant action ##S_m##. Define:$$E^{a} = \frac{1}{\sqrt{-g}} \frac{\delta S_m}{\delta \omega_a}$$Also, ##T^{ab} = \tfrac{2}{\sqrt{-g}} \tfrac{\delta S_m}{\delta g_{ab}}## is defined as per usual. We would like to derive:$$\nabla_a {T^a}_b = E^a \nabla_b \omega_a - \nabla_a(E^a \omega_b)$$The statement that ##S_m## is diffeomorphism invariant: I guess this means, under ##x\mapsto x - \xi##, and therefore$$\delta g_{\mu \nu} = (L_{\xi} g)_{\mu \nu} = \nabla_{\mu} \xi_{\nu} + \nabla_{\nu} \xi_{\mu}$$that ##S_m## is invariant... how do I use that? I imagine you can write something down in terms of the Lie derivative, and then manipulate the resulting equation into the result. But how to start??
Never mind, I figured it out. For sure, you write out$$\delta S_m = \int d^4 x \left[ \frac{\delta S_m}{\delta \omega_a} \delta \omega_a + \frac{\delta S_m}{\delta g_{ab}} \delta g_{ab} \right]$$and then stick in the expressions ##\delta \omega = L_{\xi} \omega## and ##\delta g = L_{\xi} g## in terms of covariant derivatives, as well as replacing ##\delta S_m / \delta g_{ab}## by the expression involving the energy momentum tensor. Then just integration by parts gives what you want, when you make sure it vanishes under arbitrary ##\xi##.
Please delete or close the thread if you want... (classic rubber-duck example - write something down and then figure it out)
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
