Difference between "1 kgf" and "1 N"?
In summary, the difference between 1 kgf and 1 Newton is that 1 kgf is a non-SI unit of force while 1 Newton is the SI unit of force. 1 kgf is equal to 9.8 N, and both units are derived from the equation F=ma, where F is force, m is mass, and a is acceleration. The term kgf is not recognized in SI units and is considered slang. It is important to understand and use the SI unit of force, the Newton, in scientific and mathematical calculations.
navneet9431
What is the difference between 1 kgf and 1 Newton?
About 10. Actually standard g, which is more like 9.8
Since f=ma
g N = 1 kg x g m/sec2
1 kg force = 1 kg x g m/sec2
Both are units of force. N is the SI unit. kg force is a non-SI unit.
Likes navneet9431
navneet9431 said:
1 kgf
Before getting carried away with this, where have you ever found the term "kgf" used in serious Physics? The whole point is that, in SI, Force and Mass do not share any officially named units.
When I was taught Imperial units at school, we used Poundals as the basic unit of force and lbs as Mass. If we talked about a pound force, it was frowned upon. More than fifty years later, users of Imperial units are still falling into the same sort of pitfalls. Every day, people persist with using the same sort of units that were invented when steam engines and horses and carts were the norm. Time for a serious attempt at moving to a system that was developed in a better informed era, I think. It was done successfully in UK in my lifetime (via cgs and mks) so US could easily manage it.
Likes CWatters, DrClaude and Dale
I am with @sophiecentaur on this. I have been doing this stuff for decades and never seen kgf until today. I don’t know if any system of units actually officially recognizes it
There may be confusion because one does see the units ##\mathrm{lb}\cdot\mathrm{f}## (for reasons that may be worth discussing).
My doubts are still unclear.
Is there no difference between "1 kilogram force" and "1 Newton"?
This was answered in post #2: the difference is 9.8kgf/N.
How can there be a "kilogram force"? The Force of a kilogram, doing what?
The 'old' system with pounds and feet was 'invented' when the weight of an object was thought to be more relevant than its mass. We know different nowadays.
I don't think so. Where does a force come from unless the conditions are properly specified? If you really feel it necessary, the term kgW (kilogram weight) would at least have some meaning, but even that is very sloppy.
I don't think so. Where does a force come from unless the conditions are properly specified? If you really feel it necessary, the term kgW...
https://en.m.wikipedia.org/wiki/Kilogram-force
russ_watters said:
That reference tells us that " The kilogram Force is a non standard unit and is unacceptable for use in SI"
Does that resolve the issue? I know Wiki is not the fount of all knowledge.
Yes, I think it does. it's like slang; it may not be in a normal dictionary, but people still use it and it has a definition.
Likes navneet9431
What is "g" there?Is it for grams?
I have read that 1 Newton(N)= 1 kg*m/s^2
No. In that context g is the standard acceleration due to gravity at the surface of the earth. So 1 g = 9.80665 m/s^2
Likes russ_watters
No, "g" is the standard acceleration due to gravity at the surface of the earth.
I bet you wouldn’t appreciate my entering a list of other terms that fit that description and expect them to be taken seriously, though. PF normally aims at the straight and narrow path. :smile:
Please drop it. The OP asked a specific question and I gave an accurate answer. It doesn't even conflict with yours, so there is really nothing to argue about!
In general..
Force(N) = mass(kg) * acceleration(m/s^2)
So yes..
1N = 1kg * 1m/s^2 = 1kgm/s
However as others have said, the expression kgf isn't used in SI units. I would encourage you to forget you ever heard about kgf and make sure you can understand how to work with Newtons.
Examples...
A 1kg mass sitting on a table on Earth exerts a force of 9.8N on the table.
A 100N force accelerates a 5kg mass at 20m/s^2
No argument. I'm just concerned that the OP and others shouldn't make free use of 'inappropriate' quantities or units.
I don't see a problem. A poster asked a question about an unfamiliar unit that he/she may have encountered somewhere. Whether or not one likes the units, they are out there, and an explanation can be given for what the units mean along with reasons to avoid them.
Likes Merlin3189, navneet9431 and sophiecentaur
FAQ: Difference between "1 kgf" and "1 N"?
What is the difference between 1 kgf and 1 N?
1 kgf (kilogram-force) is a unit of force in the metric system, while 1 N (newton) is a unit of force in the International System of Units (SI). They are not equivalent as 1 kgf is equal to 9.80665 N.
Can 1 kgf and 1 N be used interchangeably?
No, they cannot be used interchangeably as they are two different units of force. The conversion factor between 1 kgf and 1 N is 9.80665, so they are not equivalent.
How is 1 kgf related to 1 N?
1 kgf is equal to the force exerted by a 1 kilogram mass due to gravity on Earth, while 1 N is equal to the force required to accelerate a 1 kilogram mass at a rate of 1 meter per second squared. Therefore, they are related but not equivalent.
Why are there two different units for force?
1 kgf and 1 N are two different units for force because they are derived from two different systems of measurement. 1 kgf is derived from the metric system, while 1 N is derived from the SI system. Both systems are widely used in different parts of the world and have their own set of units for measuring force.
How do I convert between 1 kgf and 1 N?
To convert between 1 kgf and 1 N, you can use the conversion factor of 9.80665. To convert from kgf to N, multiply the value in kgf by 9.80665. To convert from N to kgf, divide the value in N by 9.80665. Alternatively, you can use online conversion tools or consult a conversion chart for accurate conversions.
