Difference between -3² and (-3)² ?
In summary, the difference between -3² and (-3)² lies in the order of operations and the placement of parentheses. -3² is evaluated as -(3²), resulting in -9, while (-3)² is evaluated as (-3) * (-3), resulting in +9. Thus, -3² equals -9 and (-3)² equals +9.
  • #36
Nugatory said:
The internal logic of an RPN calculator is appreciably simpler than that of a PEMDAS-aware calculator, which mattered when designing a palm-sized device using 1970s technology.
The first time I met with RPN was when I found a really cool looking, 'vintage, for collectors' calculator (with that classic LED display: the kind with the magnifying lenses, and with the numbers scurrying and rolling while it's sweating with the job) and noticed that I cannot do any calculations with it...
Kind of:
  • #37
That TI calculator has an “=“ key, which identifies it as a non-RPN calculator, as we’d expect from a TI calculator of the era. The RPN calculators were made by HP and had an “enter” button that did somethint completely different. The presence or absence of an ”=“ key was a big piece of the advertising wars between the two companies.
Likes e_jane and Rive
  • #38
Thanks. It was some 30+ years ago (when cheap LCD with '=' was already common) and the LEDs made the most impact - and that I could not figure it out.
By next day the battery was down and with that the thing got forgotten. I could connect the dots only when some years later at the university somebody explained the RPN properly.
  • #39
jedishrfu said:
my iPhone simple arithmetic calculator doesn't [have parentheses] either (ie in portrait mode) However switching to landscape mode and you get a full blown scientific calculator complete with parentheses.
Gee, I never knew that! :cool: I haven't used that calculator in a loooong time, ever since I found out about the RLM-11CX calculator which emulates my old HP-11C. It of course doesn't have parentheses because it uses RPN input.
  • #40
FactChecker said:
Then you will have to do the calculation in two steps in the correct order yourself and not count on the calculator. You will have to calculate ##3^2 = 9## first, and then reverse the sign to get ##-3^2 = -9##.
If you are going to get into this in a significant way, use the more advanced calculator.
I want to learn why -3²=9 ???
-x-=+
Square means a number times itself.
-3² should be -3 x-3= +9
I need to understand why the correct answer is -9 ???
  • Haha
  • Sad
Likes chwala and weirdoguy
  • #41
-x-=+
Was this already settled several posts ago at least a few times?
-3^2
The negative sign is NOT attached to the 3.
The meaning is -(3)^2 or same as -(3^2).
the exponent 2 is attached to the 3.
  • #42
-x-=+
PEMDAS, You must learn it and make it second nature before proceeding to anything else in math.
Likes Math100 and DaveC426913
  • #43
*sigh* Because of PEMDAS.
Parentheses
Exponents
Multiplication and Division
Addition and Subtraction
By mathematical convention, as taught in all modern mathematics, that is the order in which such an equation is solved.
So: when you see this: -32, you solve this ( 32 ) first.
The minus sign ( - ) in front is an operator, just like addition, multiplication or exponentiation. It operates on what is immediately to its right (i.e. 32 AKA +9 ) to turn it into its operative inverse. That is what that minus sign means. And so, it gets processed in PEMDAS order - i.e. last.
Likes Math100 and Dale
  • #44
Erm.
Depending on the exact input sequence a '-' can be either an operator or mean a negative value.
Rive said:
If your enter is something like 'minus, three, square' then (if it's anything decent) it'll do the square part first and the 'minus' last
If your enter is 'three, +/-, square' then it'll take it as a (minus-three) on square
Also, if the '-3' is produced by a calculation then it'll mean a negative value and will be processed so.
Entering the negative values by starting the input sequence with '-' is IMHO a mistake and should be avoided.
  • #45
Rive said:
Erm.
Negative value of what? Nothing should be evaluated until the input is complete. Apparently, some calculators do not allow that. IMO, PEMDAS makes ##-3^2## unambiguous no matter how it is entered.
If there is any confusion, parentheses should be used to remove any doubt about the order of the calculations.
  • #46
-x-=+
Because, as mentioned several times, the convention is that ##-3^2## is to be read as minus the square of three and not as the square of minus three. As others have commented this is part of a more general system often called PEMDAS (you may have learned BIDMAS or BODMAS and some other mnemonic, but they're all the same) which is a convention for the order in which operations are done.
So it's basically the same reason as why 2×3 + 4×5 is 26 and not 50 - because the order of operations is what it is, not just reading left-to-right.
  • #47
FactChecker said:
IMO, PEMDAS makes unambiguous no matter how it is entered.
Basic calculators has their own logic (due lack of parentheses), and if you don't understand them then it'll be ambiguous no matter how many PEMDAS got referenced.
This Windows-thing is fortunately able to display the actual operation so you can check what happens
Sequence of 'minus, three, square' => 0-sqr(3), and that's -9, proper
Sequence of 'three, +/-, square' => sqr(-3), and that's 9, proper
Basic calculators do the same operations but without allowing it to be checked
Thus: 'know your calculator'.
  • #48
Rive said:
Erm.
  1. I'm not talking about calculators; I'm answering gary's question. Calculator behavior is a side-quest in this discussion.
  2. The problem with this discussion has to do with the terminology "a negative value" (as FC pointed out: "of what?"). I'm clarifying, by pointing out that - while the minus sign does apply to the value to its right - it is an operation (it is not simply intrinsic), and that operation has to wait for order of precedence.
  • #49
He was the one bringing in calculators and expressing his confusion about them:
gary350 said:
My calculator shows -3² = 9
My calculator also shows 3²=9
Both make sense because -x-=+
-x-=- makes no sense.
Guess not attending his calculator properly might be the reason he does not feel even this many answers satisfactory. I don't know.
If there is nothing left on the left side of zero but only the right side with a mirror then I'm out of this 'precalculus mathematics homework help' topic.
  • #50
Perhaps. But 'calculators' is not 'the reason why'; it is still a side quest, even for the OP.
Possibly. It is a bad carpenter that blames his tools. :wink:
My take on this is to disabuse the OP of the notion that the minus sign is there "from the start". as if it is a "property" of the value to its right.
We're trying to get him to perform the operations in order and to do that, we need to demonstrate that the operations are discreet and in-series.
  • #51
DeBangis21 said:
Thanks. I am getting something in here. I use to wonder and always asked myself, and others, why -n^2 in my calculator gives -n instead of n.
I think I understand what you think you meant, but that's different from what you actually wrote. No calculator will display either -n or n if the input is -n^2. IOW, squaring a number won't produce that number except if the number is 1.
Parentheses
Exponents
PEMDAS doesn't really cover it, as the minus sign is really the (unary) negation operator rather than the (binary) subtraction operator.
Programming languages generally do a much better job of specifying the order of operator precedence than does mathematics. In addition, many languages also specify the associativity; i.e., how operators at the same precedence level are evaluated, whether left-to-right or right-to-left.
For example, in Python, exponentiation (denoted as **) is of higher precedence than negation (see https://www.geeksforgeeks.org/precedence-and-associativity-of-operators-in-python/). For an expression such as -3**2, 3 is squared before the result is negated. Because of the precedence of the two operators, -3**2 has exactly the same value as -(3**2).
  • #52
I think PEMDAS covers it implicitly, if not explicitly.
IOW, if one were to find a concise description of PEMDAS it might cover negation operators under subtraction operators.
Mathematics manages with its convention. You gotta know how to math.
  • #53
-x-=+
This was answered in posts 4, 14, 19, 41, plus a couple more that I might have missed. Please go back and reread them.
Not good enough if it isn't explicit. That's why I said that programming language do a much better job of explaining how expressions are evaluated. All of the descriptions of PEMDAS (or BIDMAS) I've ever seen were concise, which is the problem. And none of the letters in either acronym covers negation.
Yeah, I think I know "how to math."
Likes chwala
  • #54
One last time: ##-3^2## means "take the negative of the result of 3 squared".
There is nothing more to say, so this thread will now be closed.
  • Love
Likes hutchphd, Math100, gmax137 and 3 others
