Difference between a cathode ray tube and a magnetron?
In summary, a cathode ray tube and a magnetron are two different types of sputtering setups. While a CRT uses positive ions to dislodge surface atoms, a magnetron uses secondary electrons produced by collisions to increase the sputtering efficiency. The use of a permanent magnet in a magnetron setup allows for a longer path of these electrons, resulting in a higher probability of ionizing Ar atoms and achieving a greater number of ions at a lower pressure.
geobob
Can someone please explain to me the difference between a cathode ray tube and a magnetron? I just started using a magnetron for sputter deposition in a project for a prof, and after reading about it, it seems to be the same. Just wondering, even though it may be a stupid question!
Thanks!
A magnetron sputtering setup is nothing like a CRT. And you do not use a megnetron for magnetron sputtering. The term is used because the set-up is similar to a magnetron.
The idea with conventional sputtering is that you slam a bunch of positive ions (usually Ar+, produced by the ionization of Ar gas) into a target (the Ar+ ions are accelerated by the negative potential on the target) and the collision dislodges surface atoms, which fly off and (some of them) get deposited on the substrate. Now a side-effect of the collisions is the production of secondary electrons which shoot out of the target and fly off. . Some of these secondary electrons run into Ar atoms and help ionize them. The more Ar+ ions, the better the sputtering efficiency, so this side-effect is a good thing. But along that reasoning, one might just suggest that you simply increase the Ar pressure if you want more ions, but that is not a good idea. You need very low pressure to have essentially ballistic transport of the sputtered atoms to the substrate, if you want any kind of sputtering uniformity. So, since the secondary electrons are a good thing to have around for as long as possible, a permanent magnet is used (and hence the name 'magnetron sputtering') to make the path of the electrons a spiral (rather than a straight line). By increasing the path length you increase the probability that the electron with ionize an Ar atom, and hence achieve a greater number of ions at the same pressure. Alternatively you can achieve the same sputtering rate as a conventional sputtering arragement at a much lower pressure.
The main difference between a cathode ray tube and a magnetron is their function and design. A cathode ray tube is a vacuum tube that produces images on a screen by directing a beam of electrons onto a phosphor-coated screen. It is commonly used in older television and computer monitors. On the other hand, a magnetron is a high-powered vacuum tube that generates microwaves for use in cooking and radar systems. It is typically used in modern microwave ovens.
In terms of design, a cathode ray tube has a long, narrow shape with a cathode (negative electrode) at one end and an anode (positive electrode) at the other. The beam of electrons is created at the cathode and accelerated towards the anode, where it is focused and directed onto the screen. A magnetron, on the other hand, has a cylindrical shape with a central cathode and an anode surrounding it. The electrons are emitted from the cathode and travel towards the anode, where they interact with a magnetic field to create microwaves.
In summary, while both cathode ray tubes and magnetrons use electrons to produce their respective outputs, they have different functions and designs. A cathode ray tube is used for displaying images, while a magnetron is used for generating microwaves.
Related to Difference between a cathode ray tube and a magnetron?
What is a cathode ray tube?
A cathode ray tube (CRT) is a vacuum tube in which an electron gun at one end emits a beam of electrons that are focused and accelerated by electric fields to form an image on a fluorescent screen at the other end.
What is a magnetron?
A magnetron is a vacuum tube in which the flow of electrons is controlled by a magnetic field. It is commonly used in microwave ovens to generate the microwaves that cook food.
What are the main differences between a CRT and a magnetron?
The main difference between a CRT and a magnetron is their purpose and function. A CRT is used to display images on a screen, while a magnetron is used to generate microwaves for cooking. Additionally, a CRT uses an electron gun to create a beam of electrons, whereas a magnetron uses a magnetic field to control the flow of electrons.
Which one is more commonly used in everyday devices?
A magnetron is more commonly used in everyday devices, such as microwave ovens, while CRTs are not as commonly used due to the availability of more advanced display technologies.
Can a cathode ray tube be used as a magnetron?
No, a cathode ray tube cannot be used as a magnetron. The two have different designs and functions, and a CRT does not have the necessary components to generate microwaves like a magnetron does.
  • Quantum Physics
  • General Engineering
  • Electromagnetism
  • Atomic and Condensed Matter
  • Electromagnetism
