Difference between a tokamak and a spherical tokamak
In summary, the only difference between spherical tokamaks and conventional tokamaks is the aspect ratio, which affects the shape of the plasma. Spherical tokamaks have a lower aspect ratio, making them more spherical in shape. There is no reverse field or other non-tokamak feature in spherical tokamaks.
chandrahas
72
The title question is quite self-explanatory. Despite the fact that Spherical tokamaks are more spherical in shape, what else differentiates the ST from the conventional tokamak. I've heard that ST's use reverse field configurations from a website but I am skeptical about this since the rest suggest otherwise. Do ST' use reverse field configurations? And any other differences?
Thanks
The only difference is “aspect ratio”, the ratio of major radius to minor radio of the tokamak plasma. As the aspect ratio decreases, the plasma shape becomes less doughnut-like and more spherical-like, especially when the plasma has vertical elongation. When the aspect ratio is about 2.0 or below, the tokamak is arbitrarily called a “spherical torus” or "spherical tokamak."
There is NO reverse field or any other non-tokamak feature.
Oh. I think the reverse field thing is a part of the spheromak not the spherical tokamak . Got it. Thanks
Related to Difference between a tokamak and a spherical tokamak
What is a tokamak?
A tokamak is a device used to create and contain a plasma, which is a state of matter that is similar to a gas but made up of ions and free electrons. It is often used in experiments related to nuclear fusion, in which two or more atomic nuclei combine to form a heavier nucleus, releasing large amounts of energy.
What is the difference between a tokamak and a spherical tokamak?
A tokamak is a donut-shaped device, while a spherical tokamak is a more compact version with a smaller hole in the middle. This difference in shape affects the way the plasma is confined and heated, as well as the stability of the device.
Which one is more efficient for nuclear fusion experiments?
Both tokamaks and spherical tokamaks have been used in nuclear fusion experiments, and both have advantages and disadvantages. However, current research suggests that spherical tokamaks have the potential for higher efficiency due to their compact size and ability to produce a higher plasma pressure.
How do tokamaks and spherical tokamaks work?
In both devices, a strong magnetic field is used to confine the plasma. This magnetic field is created by large superconducting coils surrounding the device. The plasma is heated using various methods, such as radio frequency or neutral beam injection, to temperatures of millions of degrees Celsius. This allows the particles to overcome their repulsive forces and fuse together, releasing energy.
What are the potential applications of tokamaks and spherical tokamaks?
Tokamaks and spherical tokamaks are primarily used in research and development for nuclear fusion energy, as they have the potential to provide a nearly limitless source of clean energy. They can also be used to study plasma physics, astrophysical phenomena, and materials science.
  • Atomic and Condensed Matter
  • Earth Sciences
  • STEM Academic Advising
