Difference between ASE and stimulated emission
In summary, amplified spontaneous emission (ASE) and stimulated emission are both forms of stimulated emission, but they differ in the seeding photons used. While a laser aims to stimulate photons into a specific narrow cavity mode, ASE can occur when a photon spontaneously decays into a different mode, causing further decay through the stimulated process. This is considered undesirable as it drains power from the desired narrow frequency mode and contributes to broadband noise.
TheCanadian
367
Is there any inherent difference between amplified spontaneous emission and stimulated emission? Is not stimulated emission simply the mechanism by which ASE occurs? Is stimulated emission just a broader term? I've read the two terms in literature and just wanted to ensure I understood the subtle differences between them.
They are both in principle stimulated emission yes, but the seeding photons are different. What you want in a laser is that all photons in the inverted population gets stimulated down into the specific narrow cavity mode that your mirrors define. However if a photon, for example, spontaneously decays into a mode other than the lasing one it also has a chance of causing further decay through the stimulated process. This is what is called ASE, and it's generally considered bad because it drains power from the narrow frequency mode you want your laser to have and puts it into the broadband (and also undirectional) ASE, essentially acting as noise around your main laser peak.
Related to Difference between ASE and stimulated emission
1. What is the difference between ASE and stimulated emission?
The main difference between ASE (Amplified Spontaneous Emission) and stimulated emission is the source of the emitted photons. In ASE, the photons are emitted spontaneously from the excited atoms or molecules, while in stimulated emission, the photons are stimulated and emitted by an external source.
2. How do ASE and stimulated emission affect laser performance?
In ASE, the emitted photons can compete with the desired stimulated emission, leading to a decrease in laser output power and efficiency. In contrast, stimulated emission increases the laser output power and efficiency by providing a source of coherent photons that can stimulate further emission.
3. Can ASE and stimulated emission occur simultaneously?
Yes, ASE and stimulated emission can occur simultaneously in a laser system. However, the amount of ASE emission can be reduced by optimizing the laser design and controlling the gain medium's properties.
4. Which type of emission is more desirable for laser applications?
Stimulated emission is more desirable for laser applications because it provides a coherent and directional output beam, which is essential for most laser applications. ASE can lead to a decrease in laser performance and can cause unwanted noise in the laser output.
5. How can the effects of ASE be minimized in a laser system?
The effects of ASE can be minimized by optimizing the laser design, such as using a longer gain medium or reducing the gain medium's doping concentration. Additionally, using an external source to stimulate emission rather than relying solely on spontaneous emission can also help reduce the effects of ASE.
