Difference between co-ordinate covalent bonds and ionic bonds?
In summary: In the case of AlCl3, it is more accurate to view this as one of the lone pairs on a Cl atom acting as a Lewis base and donating to the empty pz orbital centered on Al in another AlCl3 monomer (with concomitant rehybridization). In summary, AlCl3 is a coordinate covalent bond because it behaves like a covalent molecule. It dissolves into its ions in aqueous solution.
Hammad Shahid
64
Right now we are learning about the Lewis definition of acids and bases.
I don't get the clear difference between co-ordinate covalent and ionic bonds. For example, AlCl3 is listed as a co-ordinate covalent bond because experiments show that it behaves like a covalent molecule. Why can't it be Al(3+) + 3 Cl(-) ?
Chemistry news on Phys.org
It could I guess except it really isn’t. Purely ionic compounds have very high boiling points but AlCl3 sublimes at less than 200C. I used to purify it by sublimation before using it in moisture sensitive reactions. A schlenk to another schlenk via a u-tube under static vacuum as I recall. You can’t do that with an ionic compound!
So there must be something going on that causes this compound to significantly share its electrons rather than transfer them. The difference in electronegativity is about 1.5 so its classed as a polar covalent bond by that (handwaving) rule. There are other rules we use to predict the ionic/covalent character in a bond like Fajan’s rule, for example. That rule states that a metal/nonmetal bond is ionic if the cation is large, has a small charge and if the anion is small. None of those are true for AlCl3. Of course these rules don’t really explain the why as much as the what but they help to predict what is observed in nature.
Try drawing the lewis dot structure for AlCl3 and see what you get. You’ll find that the Al in this compound is a couple of electrons shy of a full octet. Thus, it wants to share a couple of extra electrons which are supplied by nearby Cl in a coordinate covalent fashion.
In science, we use models to describe the essence of a particular situation. Many models have a limited range of validity. That's sort of what's going on here when you want to say something is ionic or covalent. As was mentioned by @Chemistree there is a concept of a continuum between covalent and ionic.
Not that being said, AlCl3 dissolves into its ions in aqueous solution. I don't think many chemists would call that covalently bonded.
Coordinate covalent bonds are used to get around the rule that "each atom contributes an electron to a covalent bond" in Lewis structures. In ammonium, for example, there should be a coordinate covalent bond and three covalent bonds, but in fact all 4 bonds are the same.
Likes chemisttree
No, AlCl3 reacts with water. The difference is that if you evaporate the water, you don’t get back AlCl3.
Likes Dr_Nate and chemisttree
The coordinate covalent bonding that AlCl3 undergoes can be most clearly seen in its dimer, which has a structure analogous to diborane, featuring 3-center-2-electron bonds. In the case of AlCl3, however, it’s more accurate to view this as one of the lone pairs on a Cl atom acting as a Lewis base and donating to the empty pz orbital centered on Al in another AlCl3 monomer (with concomitant rehybridization). This Lewis acid-Lewis base interaction is generally described as “coordinate covalent” (or less frequently now, “dative”).
I was kinda hoping the OP would actually try the Lewis structure thing and ponder the extra Cl.👍🏻
Yes, you are correct.
Related to Difference between co-ordinate covalent bonds and ionic bonds?
1. What is the main difference between co-ordinate covalent bonds and ionic bonds?
Co-ordinate covalent bonds involve the sharing of electrons between two atoms, while ionic bonds involve the transfer of electrons from one atom to another.
2. How do the strengths of co-ordinate covalent bonds and ionic bonds compare?
Co-ordinate covalent bonds are generally stronger than ionic bonds as the shared electrons are held more closely between the two atoms, while in ionic bonds, the attraction between the positively and negatively charged ions is weaker.
3. Can you give an example of a compound with a co-ordinate covalent bond?
An example of a compound with a co-ordinate covalent bond is carbon monoxide (CO). The carbon atom shares its electrons with the oxygen atom, resulting in a strong covalent bond.
4. How are the properties of compounds with co-ordinate covalent bonds and ionic bonds different?
Compounds with co-ordinate covalent bonds tend to have lower melting and boiling points, are more soluble in non-polar solvents, and are generally less conductive than compounds with ionic bonds.
5. Are there any similarities between co-ordinate covalent bonds and ionic bonds?
Both co-ordinate covalent bonds and ionic bonds involve the sharing or transfer of electrons between atoms to form a bond. They also both result in the formation of stable compounds.
14K
  • Atomic and Condensed Matter
