Difference between differentiating a function and an equation
In summary, the difference between differentiating a function and a equation is that a function is explicit with respect to the rest of the variables, while an equation is not necessarily valid for all values and may have different roots after differentiation. Differentiation is only meaningful for identities and not for equations.
autodidude
333
What is the difference? I always see differentiate a function but never an equation, a lot of exercises have y=blahblah which is an equation. Does it just mean that when you're asked to differentiate the equation (without using implicit), that it is satisfies the conditions for a function?
The difference is that the function case is a special case of the general case of implicit differentiation: your function is explicit with respect to the rest of the variables.
It's basically akin to the difference of say d/dx(f) instead of say d/dx(f*x) where first is df/dx and the second is x*df/dx + f.
Again its best if you think of a function as just another variable (this is it all it is) and that instead of the variable f being inter-twined where it can't be easily algebraically separated, it is explicit which means you can put f on one side and all the other variables on the other.
The reason you only see "differentiate a function" is that is the way differentiation is defined. You don't differentiate an equation, you differentiate the functions on the two sides of the equals sign.
^ Ooh, ok, thank you!
Only identities can be differentiated meaningfully. Equations are usually valid only for a select number of unknown values, and the "differentiated equation" may have a completely different set of roots. For example: [tex]3x = x^2 + 2[/tex]has roots [tex]x = 1, 2[/tex]However, differentiating, we have[tex]3 = 2x[/tex] where the root is [tex]x = \frac 3 2[/tex] This is why it rarely makes sense to differentiate equations (unless we are talking about functional equations).
FAQ: Difference between differentiating a function and an equation
What is the difference between differentiating a function and an equation?
Differentiating a function involves finding the derivative of the function with respect to its independent variable, while an equation refers to a mathematical statement that equates two expressions or functions.
What does it mean to differentiate a function?
Differentiating a function means finding the rate of change of the function with respect to its independent variable. It gives us information about the slope or gradient of the function at a particular point.
Can you differentiate an equation?
No, an equation cannot be differentiated. Differentiation is a process applied to functions, not equations. However, an equation can be used to represent a function, in which case we can differentiate the function that the equation represents.
How do you differentiate a function?
To differentiate a function, we use the rules of differentiation, which involve finding the derivative of the function with respect to its independent variable. This can be done using the power rule, product rule, quotient rule, or chain rule, depending on the type of function.
Why is it important to differentiate a function?
Differentiating a function allows us to understand its behavior and properties, such as its rate of change, maximum and minimum points, and concavity. This information is crucial in many areas of science and mathematics, including physics, engineering, and economics.
