Difference between Electric Potential energy and Potential energy
In summary, a proton released from rest in a uniform electric field of 8x10^4 V/m will have a change in electric potential and potential energy after moving 0.5 meters. The speed of the proton can also be calculated using the equation U(elec)=qEs. The electric potential is independent of the charge of the particle, but there may still be a change in electric potential if the electric field is uniform. This is because the field is the gradient of the potential, and if the gradient is a constant, the potential may still be changing. It is important to clarify the difference between electric potential and electric potential energy, as well as review the equations and definitions for these concepts.
SiriusAboutAstronomy
A proton is released from rest in a uniform electric field of magnitude 8x10^4 V/m. After the proton has moved 0.5 meters
a) What is the change in electric potential?
b) What is the change in potential energy?
c) What is the speed of the proton?
U(elec)=U(naught)+qEs
s=change in distance
q=charge of particle
E= electric field
I'm more or less looking for clarification of the problem... on part a), do you think he means what is the change in electric potential energy?
If not, how does the electric potential change? Maybe I don't know the difference well enough.
In part b) if part a) is talking about electric potential energy of the particle, does the particle gain or lose mechanical potential energy?
No. He has clearly asked for the change in electric potential.
You do need to go through your course notes for these definitions.
http://en.wikipedia.org/wiki/Electric_potential
http://en.wikipedia.org/wiki/Electric_potential_energy
What would "mechanical potential energy" be? If the particle loses potential energy from anywhere, it gains kinetic energy.
Okay, but if the electric potential is independent of the charge of the particle, and the electric field is uniform, wouldn't there be no change in the electric potential?
U(elec)=qV ==> V=U/q
I guess I am confused why he asked a) before b), because to solve it, U=qEs, and V=U/q.
So in this case V=Es? I just don't understand why there would be a change in electric potential in an infinite uniform electric field...
The field is the gradient of the potential.
You should have something like ##\vec{E}=\vec{\nabla}V## in your notes.
If the gradient is a constant - what is the function?
I would like to provide a clear explanation of the difference between electric potential energy and potential energy. Electric potential energy refers to the energy that a charged particle possesses due to its position in an electric field. This energy is dependent on the magnitude of the electric field and the charge of the particle. On the other hand, potential energy is a more general term that refers to the energy that a particle possesses due to its position in a force field. This can include gravitational potential energy, elastic potential energy, etc.
Now, moving on to the given problem. When a proton is released from rest in a uniform electric field, it will experience a force due to the electric field and will accelerate. This means that the proton will gain kinetic energy and its speed will increase. Since the proton is moving in the direction of the electric field, its electric potential energy will decrease as it moves closer to the source of the field.
a) The change in electric potential refers to the difference in electric potential energy before and after the proton has moved. In this case, the proton has moved 0.5 meters in the direction of the electric field, which means it has moved closer to the source of the field. Therefore, the change in electric potential will be negative.
b) The change in potential energy refers to the difference in potential energy before and after the proton has moved. In this case, the proton has gained kinetic energy as it accelerates in the electric field. Therefore, the change in potential energy will be positive.
c) The speed of the proton can be calculated using the equation for kinetic energy, where the change in kinetic energy is equal to the change in potential energy. We can also use the equation for the work done by the electric field, which is equal to the change in kinetic energy. Solving for the speed, we get:
KE = qΔV = (1/2)mv^2
v = √(2qΔV/m)
Using the given values, we get:
v = √(2(1.6x10^-19 C)(-8x10^4 V/m)(0.5 m)/(1.67x10^-27 kg))
v = 1.6x10^7 m/s
In conclusion, the change in electric potential is negative, the change in potential energy is positive, and the speed of the proton is 1.6x10^7 m/s.
Related to Difference between Electric Potential energy and Potential energy
What is the difference between electric potential energy and potential energy?
The main difference between electric potential energy and potential energy lies in the type of force that is being considered. Electric potential energy is associated with the electrostatic force between charged particles, while potential energy is associated with the gravitational or elastic force between objects.
How is electric potential energy calculated?
Electric potential energy is calculated by multiplying the charge of an object by the electric potential at a given point. The electric potential is equal to the electric potential energy divided by the charge of the object. Therefore, the electric potential energy can also be calculated by multiplying the electric potential by the charge of an object.
What is the relationship between electric potential energy and electric potential?
Electric potential energy and electric potential are closely related. Electric potential energy is the amount of work that is required to move a charged object from one point to another in an electric field. Electric potential, on the other hand, is the electric potential energy per unit charge at a given point in the electric field.
How does electric potential energy differ from kinetic energy?
Electric potential energy and kinetic energy are two forms of energy that an object can possess. While electric potential energy is associated with the position of an object in an electric field, kinetic energy is associated with the motion of an object. Electric potential energy can be converted into kinetic energy, and vice versa, depending on the situation.
What are some real-life examples of electric potential energy and potential energy?
Electric potential energy can be observed in everyday situations, such as when a charged balloon sticks to a wall or when a person gets an electric shock. Potential energy can be seen in objects at different heights due to gravity, such as a book on a shelf or a roller coaster at the top of a hill.
