Difference between emitter and collector?
In summary: During both saturation and active modes, you have the effect where electrons cross the base collector junction in reverse bias, moving them from a...base collector junction to an emitter collector junction.
iScience
466
Hi, i might have asked this previously but don't remember.in a BJT, could one treat the emitter as the collector and vice versa? if not, why not? what about JFETs? could one treat the drain as the source and the source as the drain?
When BJTs are operated with emitter and collector swapped they have a reduction in beta from about 100 to only about 2. They also have poor voltage breakdown characteristics.
When FETs are operated with source and drain swapped, they still behave like FETs but the gate threshold voltage is offset. Where there is an intrinsic substrate diode, the FET is effectively in parallel with a diode which prevents normal operation.
can i guess then that this might imply that the emitter is more heavily doped than the collector? and in FETs the level of doping from source to drain also varies? not sure what you mean by this though:
Of course emitter of an usual planar BJT is more heavily doped, because it's formed with double diffusion. So the thin emitter-base junction has also much greater capacitance than collector-base.
Power devices have large area collectors or drains because of heat dissipation requirements. If you operate them with polarity reversed, the specifications will have to be reduced for thermal reasons.
Any protection systems that use diode clamps will prevent operation with the component reversed.
A reverse biassed pn junction is used as an insulator in a MOSFET. When the device is reversed, that pn junction becomes forward biassed and ceases to be an insulator. It then becomes a forward biassed diode that prevents operation.
If memory serves me well, the only attraction in operating a BJT inverted is that it can give a smaller VECsat when used as a low current switch.
But better not quote me on that. :biggrin:
With a beta below 6, it would need to be a small signal being switched. I guess that BJT application has now been taken by the mosfet.
NascentOxygen; you appear to be correct, but not by much. The spice model for Si NPN shows that with base connected to collector we get Vce = 752mv, when the E and C terminals are reversed the voltage falls by 2.5% to Vec = 734mv. That is with a 10k pull-up resistor to 5V.
Base returned to collector is not a typical switch configuration.
I'm expecting VECsat of around 10mV at low current. It may be dependent upon transistor type.
more of a physics question: for BJTs, either cases of PNP or NPN have most current in the emitter, so how does the collector become the heat dissipator? i know these N and P pieces are all in close proximity, but still, why the collector and not the emitter?
wild guess: for JFETs, heat is produced towards the drain because an existing depletion region provides resistance to oncoming (electron) current, and the current moves toward the drain bringing the heat with it.
let the criticisms begin!
from semiconductor physics 2nd ed by sze, "the neutral base width is reduced to zero at sufficient Vcb and the collector depletion region is in direct contact with the emitter depletion region. at this point, the collector is effectively short-circuited to the emitter, and large current can flow."
that's as much as I'm going to quote, the math is still way over my head, for now. time for pics:
For BJTs the base current IB is small compared with ICE so we can ignore it and assume that the same current flows through the emitter as the collector. In the linear mode, VC voltage is dropped across the collector relative to VB and VE so the collector is where the W = VCE * ICE heat is generated. The same goes for the drain of a FET.
confirm this for me please let's see if i have this right
during both saturation and active modes, you have the effect where electrons cross the base collector junction in reverse bias, moving them from a region of higher potential to a region of lower potential, heating them up. during saturation you have an even greater voltage drop across the collector and emitter than you would have in active mode, but because there's more resistance in the transistor during saturation, there's simply more current (I_C) during active mode to dissipate more total energy caused by the single effect of lowering in potential.
Saturation is defined as the collector voltage being somewhere between the base and emitter voltages.
There is little power dissipated in saturation because the VCE is less than VBE.
Power is the product of voltage and current. Switching power economically requires that either the voltage or the current be close to zero.
I know a lot of books dealing with transistor physics - however, up to now, I never have seen a statement like "the collector is effectively short-circuited to the emitter, and large current can flow".
My recommendation: Forget this sentence (and change the book?); in my view: Nonsense.
In many gain stages, this "large" current is in the order of some milliamps only.
The BJT acts as a voltage-controlled (non-ideal) current source with an output resistance (at the collector) in the order of 20..100 kOhms.
The author here is talking about avalanche breakdown. The wording is a large current "can" flow, not "will" flow. It's perfectly valid, but is not something OP should be concerned with until the basic operation of the BJT has been mastered.
Thank you for the information - I did not know (I didn`t try to read the bad book reproduction); and it seems that the OP also didn`t understand the issue.
Attached is your expectation ... 5mV reversed as opposed to 20mV normal.
Likes NascentOxygen
Related to Difference between emitter and collector?
1. What is the function of an emitter in a transistor?
An emitter is the part of a transistor that is responsible for emitting or releasing electrons into the transistor's base. This flow of electrons controls the transistor's amplification of electric current.
2. How does the emitter differ from the collector in a transistor?
The emitter and the collector are both regions of a transistor that are doped differently to create a difference in electric potential. However, the emitter is heavily doped and has a larger surface area compared to the collector, which is lightly doped and has a smaller surface area. The emitter also has a higher concentration of electrons compared to the collector.
3. What is the direction of current flow in the emitter and collector?
In an NPN transistor, current flows from the emitter to the collector. This is because the emitter has a higher concentration of electrons compared to the collector, so the electrons flow towards the collector. In a PNP transistor, the current flows from the collector to the emitter.
4. Why is the emitter-base junction forward biased in a transistor?
The emitter-base junction in a transistor is forward biased to allow for a large flow of electrons to be released from the emitter into the base. This creates a low resistance path for current to flow from the emitter to the collector, enabling the transistor to amplify the current.
5. Can the roles of the emitter and collector be reversed in a transistor?
No, the roles of the emitter and collector cannot be reversed in a transistor. The doping concentrations and surface areas of the emitter and collector are specifically designed for their respective functions. Reversing their roles would result in the transistor not functioning as intended.
  • Electrical Engineering
