Difference between frame of reference and coordinate system?
In summary, the conversation discusses the concept of frames of reference and how they affect the calculation of forces and acceleration in a given situation. The participants also mention the use of fictitious forces in non-inertial frames of reference and the importance of using only inertial frames when applying Newton's Laws. The main topic of discussion is the application of these concepts in solving a specific physics problem involving a block on an elevator.
toesockshoe
265
Our teacher said we can NEVER do an F=ma problem from an accelerating, or noninertial frame. (He said there are ways to do it, but we can not do it in his class), and I'm confused becuase often times he makes the "system" or makes a "free-body diagram" around an accelerating object. Today he showed as an easy problem, but I thought it uses an accelerating frame. Here is the problem:
There is an elevator and there is a bathroom scale with a block with mass 3kg that sits on top of the scale on the bottom of the elevator. The scale reads 40N. There is another scale (a fish scale) that is attached from the ceiling to the block and that reads 20N. Find the magnitude and direction of the elevators acceleration.
F=ma
F=ma
choose positive y in coordinate system to go downward
-FT+Fg-FN=ma
-FT+mg-FN=ma
a=(mg-FT-FN)/m
plug in values, ((3)(10)-20-40)/3=-10m/s/s... (we assumed gravity is 10 downward),
b/c C.S. is going downward the elevator is accelearing upward at 10 m/s/s.
but isn't hte mass accelerating? how can that be the system?
[/B]
toesockshoe said:
F=ma
-FT+Fg-FN=ma
-FT+mg-FN=ma
a=(mg-FT-FN)/m
Seems to me that the frame used is inertial, not a frame tied to the accelerating mass. I can't understand why you think it is.
ok so what is the frame in this situation?
One fixed in relation to the Earth (which is considered inertial for most everyday purposes; have to be more careful where the spin of the Earth becomes significant).
You mean frame of reference. It is the Earth. You see the lift, the block in it, and the scales, from the ground. All accelerate together, and the acceleration of the block is determined by the sum of forces: gravity, the normal force from the bathroom scale and T tension from the fish scale.
In the frame of reference fixed to the lift, the block would be in rest (with respect to the lift) .
oh ok. got it. correct me if I am wrong: Forces acting on an object are the same in ALL frames of references but the only difference may be in the acceleration of the object right?
The forces are equal in all inertial frame of reference.
In non-inertial frames of reference there are additional fictitious forces, causing acceleration of the object. Such force push you back in an accelerating car.
ok but excluding pseudo forces (our teacher said we can't use them), would all the forces be the same but the only difference is the acceleration right>
The "real" forces are the same, but the acceleration is different. Use only inertial frames of reference, where Newton's Laws apply. Do not worry, what happens in a non-inertial one.
Related to Difference between frame of reference and coordinate system?
1. What is a frame of reference?
A frame of reference is a set of coordinate axes used to describe the position and motion of an object in space. It is a point of view or perspective from which observations and measurements are made.
2. What is a coordinate system?
A coordinate system is a mathematical system used to represent the position of an object in space. It consists of a set of reference axes, a set of units, and a set of rules for determining the coordinates of points in space.
3. What is the difference between a frame of reference and a coordinate system?
The main difference between a frame of reference and a coordinate system lies in their purposes. A frame of reference is a point of view used to make observations and measurements, while a coordinate system is a mathematical tool used to represent the position of an object in space. A frame of reference is a qualitative concept, while a coordinate system is a quantitative concept.
4. How are frame of reference and coordinate system related?
A coordinate system is defined within a frame of reference. The frame of reference provides a point of view from which the coordinates can be measured and described. Without a frame of reference, a coordinate system would have no meaning or use.
5. Why is it important to understand the difference between frame of reference and coordinate system?
Understanding the difference between frame of reference and coordinate system is important in the scientific field, particularly in physics and engineering, where precise measurements and calculations are necessary. It allows us to accurately describe and analyze the position and motion of objects in space, and to communicate this information to others in a standardized manner.
