Difference between global and local gauge symmetries
In summary, the distinction between global and local gauge transformations lies in their physical interpretation in theoretical physics. While global gauge transformations are considered to be physical symmetries of a theory, local gauge transformations are seen as redundancies that represent redundant degrees of freedom. This can be seen in classical electromagnetism, where under a local gauge transformation the 4-potential is changed while the physically measurable field strength remains unchanged. This redundancy is due to the non-uniqueness of the quantities used to describe the theory, and not a physical symmetry of the system. On the other hand, global symmetries are considered to be true physical symmetries with an associated Noether current. The distinction between these two types of transformations can be further understood
Frank Castle
580
23
The mantra in theoretical physics is that global gauge transformations are physical symmetries of a theory, whereas local gauge transformations are simply redundancies (representing redundant degrees of freedom (dof)) of a theory.
My question is, what distinguishes them (other than being global and local - independent and dependent on spacetime coordinates)? In particular, why is one (global gauge symmetry) considered to be a physical symmetry with an associated Noether current, whereas the other (local gauge symmetry) is not?
For example, the archetypal gauge theory is classical electromagnetism: under a local gauge transformation the 4-potential ##A^{\mu}(x)## transforms as $$A^{\mu}(x)\rightarrow A'^{\mu}(x)=A^{\mu}(x)+\partial^{\mu}\Lambda(x)$$ This, however, leaves the physically measurable field strength ##F^{\mu\nu}(x)## unchanged, i.e. $$F^{\mu\nu}(x)\rightarrow F'^{\mu\nu}(x)=F^{\mu\nu}(x)$$ As I understand it, this is what is meant by a local gauge symmetry being a redundancy in the description of the physical theory, since it simply reflects the fact that the physically unmeasurable quantities used to describe the theory, in this case ##A^{\mu}##, are not uniquely defined. They are introduced as a convenience to describe the theory, and their non-uniqueness is a relic of how we use them to represent physical quantities, and not due to some physical symmetry of the system. (Another example would be in GR - coordinates are introduced to describe physical quantities locally (i.e. project a tensor onto a particular coordinate basis), however, such coordinates are not uniquely defined, one can choose any set of admissable coordinates to describe the same physical quantity).
When it comes to a global symmetry, however, I'm not sure at all how to argue why this is a physical symmetry as opposed to simply a redundancy in the description of the physical theory?!
Anyone got any thoughts on this? Any help would be much appreciated!
Related to Difference between global and local gauge symmetries
1. What is a gauge symmetry?
A gauge symmetry is a mathematical concept in physics that describes the invariance of a physical theory under a certain transformation. It is a type of symmetry that allows for the same physical results to be obtained even when the underlying parameters are changed.
2. What is the difference between global and local gauge symmetries?
The main difference between global and local gauge symmetries lies in the scope of their transformations. A global gauge symmetry holds for all points in space and time, while a local gauge symmetry allows for transformations at each individual point in space and time.
3. How do global and local gauge symmetries affect the laws of physics?
Global gauge symmetries do not affect the laws of physics, as they are simply a mathematical description of the invariance of a theory. However, local gauge symmetries can have a significant impact on the laws of physics, as they allow for certain quantities to be changed at each point in space and time, leading to different physical results.
4. Can you give an example of a global and local gauge symmetry in physics?
A commonly cited example of a global gauge symmetry is the conservation of electric charge. The total electric charge of a system remains constant, regardless of changes in the underlying parameters. An example of a local gauge symmetry is the gauge invariance in the theory of electromagnetism, where the potential of the electromagnetic field can be changed at each point in space without affecting the physical results.
5. Why are gauge symmetries important in physics?
Gauge symmetries play a crucial role in modern physics, as they provide a framework for understanding the fundamental laws of nature. They allow for the development of theories that are consistent with experimental observations and help to explain the underlying structure of the universe. Additionally, gauge symmetries have been instrumental in the development of important theories such as quantum mechanics and general relativity.
  • Other Physics Topics
