Difference between many chemically related terms?
In summary, Valence bond theory, VSEPR, and molecular orbital theory are all related in their goal of explaining chemical bonding, but differ in their approach and capabilities. VB focuses on valency, VSEPR on electron repulsion, and MO on atomic orbital combinations. Each theory has its own strengths and limitations, and a combination of them is needed for a complete understanding of chemical bonding.
Vivan Vatsa
In chemistry, chemical bonding is a very important topic.
What I can't really understand is the interrelation of different theories which explains the same kind of thing, like for structure of any compound there are theories like Valence bond theory or VSEPR or molecular orbital theory.
I am having trouble in understanding the relationship & the basic core of all these theories...!
Help is must needed...!
Chemistry news on Phys.org
Sorry, we can't do work for you, and your question is way too general to answer.
Please read about all these theories and come back when you have specific questions. Or try to post a specific question if you have one.
These is an extremely general question. It is actually hard for me to answer.
Valence bond theory, VSEPR, and molecular orbital theory are all related in a sense that they are trying to explain bonds, specifically the stability (energy) of the bond, the shape of the molecule arising from such bond, interpretation of bond structure, etc. Their ultimate goal would be to predict what kind of bond, and therefore the molecule we would get from reaction of atoms. The difference is the way each theory approaches to achieve the answer.
In summary, same goal, different method.
You should consider to consult a book on Quantum chemistry. Almost all have a chapter where the different approaches are compared. Maybe Ira Levine, "Quantum Chemistry" is not too hard a starting point.
While they are all related, as stated, they do different things. VB was an initial attempt to understand chemical bonding based on the idea of valency. Atoms use valence electrons to gorm bonds. VSEPR uses the idea that electrons repel and the molecule adopts a specific geometry in order to achieve the least repulsion possible. MO theory describes bonding in terms of the combination of atomic orbitals from atoms to form MO's based on symmetry. VB can predict certain things that MO cannot and vice versa. Both theories are efficient in their own way and both are needed to understand chemical bonding. There is no single theory to get a complete picture although in my opinion MO theory is more detailed.
Read Linus Pauling "The Nature of the Chemical Bond"
Related to Difference between many chemically related terms?
1. What is the difference between elements and compounds?
Elements are substances that cannot be broken down into simpler substances by chemical means. They are made up of only one type of atom. Compounds, on the other hand, are made up of two or more elements that are chemically bonded together.
2. How is a mixture different from a compound?
A mixture is a combination of two or more substances that are physically combined and can be separated by physical means, such as filtering or distillation. A compound, on the other hand, is a pure substance that is made up of two or more elements chemically bonded together and cannot be separated by physical means.
3. What is the difference between a chemical formula and a chemical equation?
A chemical formula is a shorthand notation that represents the elements and their ratios in a compound. A chemical equation, on the other hand, is a representation of a chemical reaction, showing the reactants and products involved and the balanced chemical formula for each substance.
4. Is there a difference between an atom and a molecule?
Yes, there is a difference between an atom and a molecule. An atom is the smallest unit of an element that retains its properties. It is made up of protons, neutrons, and electrons. A molecule, on the other hand, is the smallest unit of a compound that retains its chemical properties. It is made up of two or more atoms bonded together.
5. What is the difference between an acid and a base?
Acids are substances that release hydrogen ions (H+) when dissolved in water, while bases are substances that release hydroxide ions (OH-) when dissolved in water. Acids have a pH less than 7 and taste sour, while bases have a pH greater than 7 and taste bitter. They also have opposite chemical properties and can neutralize each other.
