Difference between mass and volume
In summary, the conversation discusses the concepts of volume and mass in relation to a beaker filled with 250 ml of water. The volume and mass of the water are both determined to be 250 ml. The difference between mass and volume is explained as the measure of difficulty in moving or changing the velocity of a body, and the concept of density is introduced as the ratio of mass to volume. The conversation also suggests using a unit converter to find the density and ultimately calculate the mass of the water.
logearav
338
I have a beaker of capacity 500 ml and i fill it with 250 ml. Now, what is mass and volume of water?
Volume is the space occupied by matter, so i presume 250 ml is the volume of water. Mass is the quantity of matter, so again 250 ml is the mass of the water. Then what difference does mass and volume have?
The mass of a body is a measure of the difficulty a body meets with if :
a) it is to start moving given it was at rest
or
b) it is to stop given it was moving
or
c) it is to change its velocity.
The easiest way to understand you problem is using the units. Using this site http://www.wolframalpha.com/input/?i=litre" under the "Physics quantities" tab we see that a Litre is a measure of volume.
A volume is the "space" inside of an object. So the water that is poured into the 500ml (ml=milliLitre or 1ml = 0.0001 * 1 litre ) container occupies 250ml. That is the volume of water.
To find the mass you require to know the density of water. Density is defined as
[itex] density=\frac{mass}{volume} [/itex]
we usually give this in a mass per unit volume form, so you need to find this value. Then check that the units match with those you are using and find the mass.
FAQ: Difference between mass and volume
What is the definition of mass?
Mass is a measure of the amount of matter in an object. It is often measured in kilograms or grams.
What is the definition of volume?
Volume is the amount of space occupied by an object or substance. It is often measured in cubic centimeters or liters.
How are mass and volume related?
Mass and volume are two different properties of matter, but they are related. Mass is often used to measure how much matter is in an object, while volume is used to measure how much space the object takes up. They can be used together to determine the density of an object.
What is the difference between mass and weight?
Mass and weight are often used interchangeably, but they are not the same thing. Mass is a measure of the amount of matter in an object, while weight is a measure of the force of gravity on that object. Mass remains constant regardless of location, while weight can vary depending on the strength of gravity.
How can mass and volume be measured?
Mass and volume can be measured using various tools and techniques. Mass can be measured using a scale, while volume can be measured using a graduated cylinder or by calculating the dimensions of an object. Both mass and volume can also be measured indirectly through other properties, such as density or displacement.
