dheeraj
- 8
If the amount of hidden information inside a black hole, depends on the size of the hole, one would expect from general principles, that the black hole would have a temperature, and would glow like a piece of hot metal. But that was impossible, because as everyone knew, nothing could get out of a black hole. Or so it was thought, but stephen hawking discovered that particles can leak out of a black hole. The reason is, that on a very small scale, things are a bit fuzzy. This is summed up in the uncertainty relation, discovered by Werner Heisenberg in 1923, which says that the more precisely you know the position of a particle, the less precisely you can know its speed, and vice versa. This means that if a particle is in a small black hole, you know its position fairly accurately. Its speed therefore will be rather uncertain, and can be more than the peed of light, which would allow the particle to escape from the black hole. The larger the black hole, the less accurately the position of a particle in it is defined, so the more precisely the speed is defined, and the less chance there is that it will be more than the speed of light,. A black hole of the mass of the sun, would leak particles at such a slow rate, it would be impossible to detect. However, there could be much smaller mini black holes. These might have formed in the very early universe, if it had been chaotic and irregular.these are what called primordial black holes, aren't they?
then in what way a micro black hole is different from a primordial black hole?
