Difference between O and E rays to S and P polarizations
In summary, birefringence and crystal optics involve a distinction between O and E rays and S and P polarizations. The O-ray is equivalent to S-polarization while the E-ray is equivalent to P-polarization. However, the input light can also be described as S or P polarized without being specifically labeled as the O or E ray. It is recommended to specify the relationship between polarisation vector and optic axis rather than using the jargon labels.
CGandC
326
34
The problem relates to birefringence and crystal optics.
What is the difference between O and E rays to S and P polarizations?
Is O-ray just a different name to S-polarization and E-ray a different name to P-polarization? if not, what is the difference?-
Science news on Phys.org
It's been a while since I studied this, so do be aware that this is my rather hazy memory.
Imagine a beam of polarised light incident on the surface of a birefringent crystal. You can look at the polarisation of the light and compare it to the optical axis of the crystal, and say that the light is in the S or P polarisation, or somewhere between. But it's neither the ordinary nor extraordinary ray - that distinction doesn't arise until the beam strikes the crystal and splits into two.
So light in the O ray is S polarised and light in the E ray is P polarised (I think I got that the right way round). The input light may be meaningfully said to be S or P polarised or in between, but it is neither the O ray nor the E ray.
It's just jargon, anyway. I'd say that, if in doubt, specify the relationship between the polarisation vector and the optic axes and don't worry about the labels.
Related to Difference between O and E rays to S and P polarizations
1. What is the difference between O and E rays?
O and E rays are two types of electromagnetic waves that are commonly used in optics. The main difference between them is their polarization direction. O rays have their electric field oscillating in a direction perpendicular to the direction of propagation, while E rays have their electric field oscillating in a direction parallel to the direction of propagation.
2. What is the difference between S and P polarizations?
S and P polarizations are two types of polarization that describe the orientation of the electric field of an electromagnetic wave. S polarization, also known as transverse electric (TE) polarization, has its electric field oscillating in a direction perpendicular to the plane of incidence. P polarization, also known as transverse magnetic (TM) polarization, has its electric field oscillating in a direction parallel to the plane of incidence.
3. How are O and E rays related to S and P polarizations?
O and E rays are related to S and P polarizations in that O rays correspond to S polarization and E rays correspond to P polarization. This means that the electric field of an O ray is perpendicular to the plane of incidence, while the electric field of an E ray is parallel to the plane of incidence.
4. Which type of polarization is more commonly used in everyday applications?
S polarization is more commonly used in everyday applications because it is easier to produce and manipulate compared to P polarization. S polarized light is also less susceptible to interference and scattering, making it more useful in practical applications.
5. How do O and E rays and S and P polarizations affect the behavior of light?
The behavior of light is affected by the polarization of the light. O and E rays and S and P polarizations determine how the electric field of the light wave is oriented, which in turn affects how the light interacts with different materials and surfaces. For example, S polarized light is more likely to be reflected off of a smooth surface, while P polarized light is more likely to be transmitted through the surface.
9K
