Difference Between Plasma and Radiation
In summary: Van Allen radiation belts are a plasma that is thought to originate from the solar wind and cosmic radiation. It appears to be mostly protons and electrons and is somewhat confined by the Earth's magnetic field.
hamzaaaa
31
Hi all
In general sometimes we talk about plasma effects on satellites and radiation effects on satellites. Can someone tell the difference between the two?
Thanks and Best Regards
Hamza
Astronomy news on Phys.org
Plasma consists of electrically charged particles, whereas radiation is EM photons. Plasmas are more destructive. Energetic EM radiation can, however, generate plasmas in Earth's atmosphere.
I'm assuming that the term radiation is used in this way only for talking about the two effects on satellites? As radiation can also be charged particles.
Yes normally when we look at the two effects we talk about plasma and radiation.
But another thing I don't understand is Van Allan Radiation Belt. The name says its a radiation belt but it is a constituent of plasma. And then there is another plasma sheet which trails at the dark side of the Earth in outerspace.
A plasma is simply an ionized gas in which electrons are separated from nuclei or ions. The energies required to ionize atoms is on the order of eV. Some plasmas, particularly fusion plasmas would have temperatures in the keV range, which is low energy for radiation. Radiation would encompass ions, electrons and photons, over a broad range of energies.
High energy radiation has energy in the high keV to MeV range.
The Van Allen radiation belts are a collection of plasma or radiation that are thought to originate from the solar wind and cosmic radaition. It appears they are mostly protons and electrons, which are somewhat confined by the Earth's magnetic field.
http://en.wikipedia.org/wiki/Van_Allen_radiation_belt
http://rbsp.jhuapl.edu/science/overview.php
Hi good question. A plasma is a collective group of charged particles. It consists of both positive and negative particles and there has to be enough particles present in a volume so that they interact in a collective way.
So if a spaceship meets a plasma the plasma particles will move to shield the electrical field from the spaceship so that the field is zero inside the plasma. This is called Debye shielding.
Radiation can be single particles of either positive or negative charge and of course photons. There is no collective behaviour. You can get radiation from a plasma. In fact a little plasma radiation brightens up everybody on the beach.
Plasmas can cause damage by their collective behaviour. By trying to shield an electrical field they can charge up a spacecraft and cause particles from the plasma to strike the spacecraft at high speeds and damage the space craft.
Related to Difference Between Plasma and Radiation
What is the difference between plasma and radiation?
Plasma is a state of matter in which the atoms are ionized, meaning they have lost or gained electrons. Radiation, on the other hand, refers to the emission or transmission of energy in the form of waves or particles.
How are plasma and radiation related?
Plasma can produce radiation when excited atoms release energy in the form of light or other electromagnetic waves. Additionally, radiation can ionize atoms to turn them into plasma.
Can plasma be a form of radiation?
Yes, plasma can produce and emit radiation, but it is not considered a form of radiation itself. Radiation is a type of energy, while plasma is a state of matter.
Which one is more dangerous, plasma or radiation?
It depends on the intensity and exposure time. Both plasma and radiation can be harmful in certain circumstances. Plasma can cause burns and radiation can damage cells and DNA, leading to health issues. However, plasma is typically contained and controlled, whereas radiation can spread and have long-term effects.
What are some examples of plasma and radiation?
Examples of plasma include the sun's corona, lightning, and neon lights. Examples of radiation include X-rays, microwaves, and gamma rays. Both plasma and radiation can also be found in nuclear reactions, such as in stars and nuclear power plants.
  • Astronomy and Astrophysics
