Difference between pressure antinodes and displacement node?
In summary: The term "pressure antinode" refers to a point of maximum pressure variation, not a point of negative pressure. In summary, the conversation discusses the concept of displacement nodes and pressure nodes in relation to an organ pipe with one open and one closed end. The correct answer is B, with the closed end being a pressure node and the open end being a displacement node. The explanation for this is that a displacement node refers to a point where the medium does not move, while a pressure antinode refers to a point of maximum pressure variation. The pressure at the closed end of the pipe increases because of the combined pushes of the slices of air from the node to the wall, thus forming a pressure antinode.
eprparadox
138
An organ pipe with one end open and the other closed is operating at one of its resonant frequencies. The open and closed ends are respectively:
A. pressure node, pressure node
B. pressure node, displacement node
C. displacement antinode, pressure node
D. displacement node, displacement node
E. pressure antinode, pressure node
So the answer is B.
[/B]
The pressure node makes sense because the pressure is just whatever atmospheric pressure is. IE, there is no over-pressure at the open end.
But I get confused about why a displacement node is the same as an antipressure node.
I've looked at http://hyperphysics.phy-astr.gsu.edu/hbase/Waves/standw.html and it says
"A node for displacement is always an antinode for pressure and vice versa, as illustrated below. When the air is constrained to a node, the air motion will be alternately squeezing toward that point and expanding away from it, causing the pressure variation to be at a maximum. "
Intuitively, where there are a lot of particles, there will be high pressure. But that's not what this is saying. And what exactly does "displacement node" actually mean?
Thanks so much.
Displacement node means that a very thin slice of the medium at the node does not move (zero displacement). For example, right at the wall of a closed pipe the air can't move. However the pressure at the wall rises and falls while the particles vibrate with a small amplitude. You seem to think that particles actually move and congregate near the wall thus raising the pressure. This is not the case. The pressure at the wall increases because slice 1 of air at a node pushes slice 2 next to it and the combined pushes of slices 1 and 2 push slice 3 and so on until the wall, which cannot move, experiences the combined pushes of all the slices from the node to it thus forming a pressure antinode. If you understand this, then you will understand why at any displacement node, whether there is a wall to constrain the medium from moving or not, there will be pressure antinode.
BTW, there is no such thing as an antipressure node.
Related to Difference between pressure antinodes and displacement node?
1. What is the difference between pressure antinodes and displacement nodes?
Pressure antinodes are points in a standing wave where the pressure oscillations are at their maximum, while displacement nodes are points where the displacement of the medium is at its minimum.
2. How are pressure antinodes and displacement nodes related to each other?
In a standing wave, pressure antinodes and displacement nodes occur at the same locations. This means that where the pressure is highest, the displacement is at its lowest, and vice versa.
3. How are pressure antinodes and displacement nodes determined?
Pressure antinodes and displacement nodes are determined by the wavelengths of the standing wave. They occur at points that are half a wavelength apart from each other.
4. Can pressure antinodes and displacement nodes exist separately?
No, pressure antinodes and displacement nodes always occur together in a standing wave. They are two different aspects of the same phenomenon.
5. What are some examples of where we can observe pressure antinodes and displacement nodes?
We can observe pressure antinodes and displacement nodes in various systems such as musical instruments, sound waves in pipes, and electromagnetic waves in antennas.
  • Electromagnetism
