Difference between relative risk and odds ratio
In summary, the odds ratio can be used as an estimate for the relative risk in cases where the disease is rare and calculating the relative risk would require a large sample size. This is because the odds ratio is less sensitive to sample size and has a smaller variance. However, the two measures are not interchangeable and have different interpretations. The odds ratio can also be a more cost-effective and easier approach to estimating the relative risk in certain cases.
jaumzaum
434
33
Hello!
I was studying odds ratio and its relation to relative risk. By what I understood, the statistics that is indeed important for us and that have a nice interpretation for the context is relative risk (I was also wondering if odds ratio has any interpretation). But relative risk sometimes is difficult or expansive to calculate, because we need the prevalence of the disease, and for rare diseases this means a big sample.
So what many studies do is to calculate the odds ratio and interpret it as being nearly the relative risk. And that's true for rare diseases.
I have two things that I didn't understand, considering this example from wikipedia:
This is a village from 1000 people and we want to study if a radiation leak increased the incidence of a disease.
RR = (20/400)/(6/600)=5
OR = (20/380)/(6/594)=5.2
I understand how this values were calculated.
Then they say that, for many studies, we rarely have information about the whole population. They take a sample of 50 cases, 25 that were exposed to the radiation leak and 25 that weren't:
And they calculate de OR = (20/10)/(6/16)=5.3
They say the OR of the sample is a good estimate of the OR of the population, and then, using the rare disease assumption, that it is also a good estimation of the relative risk of the population.
But when we try to calculate the relative risk for the sample, we have some problems:
RR = (20/30)/(6/22)=2,4
My question is, why is the OR of the sample a good estimate of the OR of the population, but not the RR?
And also, if there is any interpretation for the OR?
Thanks !
Thanks @gleem, I've read the article, and it provides very good examples, but it still doesn't answer my primarily question, why is the OR of a sample a good estimate of the OR of the population? And also, if OR has any real meaning/interpretation, or if it is only a mathematical tool to estimate Relative Risk?
Now I find out that I have been using the term "odds" wrong all this time!
It would seem to me that it becomes a better predictor of the population as the sample size increases like any other statistic. How well it predicts the actual value depends on its variance.
Your data and table are not consistent Healthy + disease should = 25 for exposed and unexposed.
I redid your table
DiseaseHealthy
exposed1510
unexposed619
OR =(15/10) / (6/19) = 4.75
RR = (15/25) / (6/25) = 2.5
If in my table above, I normalize the healthy unexposed persons to the healthy exposed i.e. 10, then for every 10 healthy unexposed persons we have 3.157 sick unexposed persons which give 4.75 exposed sick persons for every unexposed healthy person.
The two measures are very different. The maximum value for the RR numeraror is ##1##. Whereas, there is no maximum for the OR numerator. Meanwhile, assuming, a low natural disease rate, the denominator may be similar in both cases.
The two, therefore, have different ranges.
You have to understand how to interpret the two numbers. The calculation of actual risk should be similar in both cases, but will need different calculations.
Thanks @gleem and @PeroK
I redid your table
DiseaseHealthy
exposed1510
unexposed619
Sorry for the misspelling. When I said "They take a sample of 50 cases, 25 that were exposed to the radiation leak and 25 that weren't", the correct was "They take a sample of 52 cases, 26 have the disease and 26 doesn't"
You said
I understand that, but it seems that the odds ratio of a sample has always a smaller variance than the relative risk for any given sample size, and thus provide a better estimate. I wish to understand why this is true.
In Wikipedia they also say that OR is a much easier and less expensive approach to estimate the RR, because we can extrapolate the OR of the sample, but we cannot extrapolate the RR of the sample if it is not big enough. Indeed, in the example given, the OR was 5.3 and the RR was 2.4, recalling that the OR and RR of population were 5.2 and 5 respectively
As a mathematician this confused me for a bit, but then I realized this is amazing.
I'm going to pick some new numbers. Suppose a town of about twenty thousand people has 130 cases of testicular cancer. You think that's a big high, so you go to investigate.
It turns out 50 of them refused to forward a chain mail that threatened to turn big men into little girls if it wasn't forwarded.
There's no way this is a real effect is is? But think of the publicity if you can manage to squeak out a .05 p value. So you decide to dig further.
The first thing you need to know is what fraction of the men in this town refused to forward the email. Let's say the real numbers are: there are 8500 men. 500 of them refused to forward the chain mail, and 10% of them got cancer. 8000 of them either didn't get the chain mail, or wisely forwarded it to ten recipients. 1% of them got cancer.
The relative risk is therefore 10.
The odds ratio is (50/450)/(80/7920)=11
But how can we get these numbers? What if we don't even know how many men are in the town? You could go house to house and ask everyone in town, but that's a lot of work, and you're only doing it if you can squeeze some grant money out of this sucker. So you decide to post up at the local McDonald's and just ask every man that comes through about it. Hopefully that's a representative sample to submit to the nih.
At the end of the day, 18 men are willing to respond to your survey. 17 say they did not get the email, or they forwarded it. 1 says they refused.
We call this the healthy sample.
Note the true ratio is 450/ 7920 people, or 1 out of 17.6, so we got almost perfect sample. About one out of every 450 healthy men in the town came through mcdonalds and answered our survey. Of course, we don't actually know this.Let's compute some odds. 50 people got cancer per 1 respondent: 50/1
80 people got cancer out of 17 respondents: 80/17
(50/1)/(80/17) = (50/450)/(80/7650)=10.6
I just multiplied the denominators by 450 to prove the point. This is almost exactly the same odds ratio as before. In fact, if we had a perfect sample of people who did not have cancer, we would get exactly the same odds ratio as before. If you multiply both denominators by .01 for example, the number is unchanged. In some sense both fractions have the same units, something like people who got cancer per 1 450th of a person who didn't get cancer, so dividing one by the other is a reasonable ratio.Now let's compute relative risk. Well (50/(50+1))/(80/(80+17)=1.19
Fundamentally, what went wrong is we're adding two incompatible numbers. 50 is all the people who refused to send the mail that got cancer. 1 is a very small fraction of the people who didn't get cancer. So 50+1 is not a meaningful number to divide 50 by. It has no meaningful units. If you wanted to get the right answer, you could do something like know your sample is 1/450th of the healthy population, and try to compute the true risks. This requires you to know that 450 number though, which often you don't. All we know is in our sample of all the sick people and a couple of healthy people, almost everyone has cancer, which doesn't help.
FAQ: Difference between relative risk and odds ratio
What is the difference between relative risk and odds ratio?
The relative risk (RR) is a measure of the strength of association between an exposure and an outcome. It compares the risk of developing a disease or outcome in a group exposed to a certain factor to the risk in a group not exposed. The odds ratio (OR) is also a measure of association, but it compares the odds of developing a disease or outcome in the exposed group to the odds in the unexposed group.
How are relative risk and odds ratio calculated?
The relative risk is calculated by dividing the risk of the outcome in the exposed group by the risk in the unexposed group. The odds ratio is calculated by dividing the odds of the outcome in the exposed group by the odds in the unexposed group.
Which measure is more commonly used in epidemiological studies?
The relative risk is more commonly used in epidemiological studies because it directly measures the risk of developing a disease or outcome in the exposed group compared to the unexposed group. It is also easier to interpret and is less affected by the prevalence of the outcome in the study population.
When should relative risk be used instead of odds ratio?
Relative risk should be used when the outcome of interest is rare, as the odds ratio can overestimate the association in this situation. Additionally, when the outcome is not rare, the odds ratio and relative risk will be similar and either measure can be used.
Can relative risk and odds ratio be interpreted in the same way?
No, relative risk and odds ratio should not be interpreted in the same way. A relative risk of 1 indicates no association between the exposure and outcome, while an odds ratio of 1 indicates no difference in odds between the exposed and unexposed groups. Additionally, the relative risk is a direct measure of risk, while the odds ratio is an indirect measure of risk.
