Difference between Renewal Process and Poisson Processes
In summary, the main difference between a renewal process and a Poisson process is the distribution of the intervals between events. While the arrival times of events in a renewal process can follow any distribution, they follow a Poisson distribution in a Poisson process. These two processes are used for different purposes: renewal processes for modeling intermittent events and Poisson processes for modeling constant events. A Poisson process can also be a renewal process, but not all renewal processes are Poisson processes. To determine whether a process is a renewal process or a Poisson process, we can look at the distribution of intervals between events, with an exponential distribution indicating a Poisson process, or the arrival times of events, with a Poisson distribution indicating a Poisson process
thrillhouse86
80
Hey All,
Can someone please explain to me the difference between a Poisson Process and a Renewal Process ? is it just that the Holding times for Poisson processes are exponential and Holding times for Renewal Processes are any kind of probability distribution (as the wiki page seems to imply)
If this is the case I don't understand why on the wiki page when reffering to the "Proof of the renewal equation" they invoke the Markov property - which I thought only held for memoryless (i.e. exponential ) distributions
Thanks
in advance!</code>A:The major difference between the two processes is that a Poisson process is a continuous-time process, while a renewal process is a discrete time process. A Poisson process is characterized by the probability of an arrival occurring at any given instant, while a renewal process is characterized by the probability of an arrival happening at any discrete point in time.In a Poisson process, arrivals of events occur randomly and independently of each other, and the interarrival times follow an exponential distribution. This means that the probability of an event occurring at any given time is the same no matter how many events have already occurred.In contrast, a renewal process follows a different probability distribution for interarrival times, and the probability of an event occurring at any given time is dependent on how many events have already occurred. This means that the probability of an event occurring at any given time is not constant, but rather changes depending on the history of past events. This is why the Markov property is necessary to prove the renewal equation - because the probability of an event occurring at any given time is dependent on the history of past events.
Related to Difference between Renewal Process and Poisson Processes
Q1: What is the main difference between a renewal process and a Poisson process?
A renewal process is a stochastic process where the intervals between events are independent and identically distributed. On the other hand, a Poisson process is a special case of a renewal process where the intervals between events follow an exponential distribution. Therefore, the main difference between the two is the distribution of the intervals between events.
Q2: How are the arrival times of events different in renewal and Poisson processes?
In a renewal process, the arrival times of events are completely random and can follow any distribution, as long as the intervals between events are independent and identically distributed. In contrast, in a Poisson process, the arrival times of events follow a Poisson distribution, which is a special case of the exponential distribution.
Q3: Are renewal and Poisson processes used for different purposes?
Yes, renewal and Poisson processes are used for different purposes. Renewal processes are often used to model systems with intermittent or sporadic events, such as machine breakdowns or customer arrivals. Poisson processes, on the other hand, are commonly used to model systems with a constant rate of events, such as radioactive decay or telephone calls in a busy line.
Q4: Can a Poisson process also be a renewal process?
Yes, a Poisson process can also be a renewal process, but not all renewal processes are Poisson processes. As mentioned earlier, a Poisson process is a special case of a renewal process where the intervals between events follow an exponential distribution. Therefore, a renewal process with exponential inter-arrival times is a Poisson process.
Q5: How do we determine whether a process is a renewal process or a Poisson process?
To determine whether a process is a renewal process or a Poisson process, we need to look at the distribution of the intervals between events. If the intervals follow an exponential distribution, then the process is a Poisson process. However, if the intervals follow any other distribution, then the process is a renewal process. Additionally, we can also look at the arrival times of events. If they follow a Poisson distribution, then the process is a Poisson process.
