Difference between second moment of area and section modulus
In summary, the difference between the two moments of inertia is that the mass moment of inertia describes the distribution of mass about the center of gravity, while the second moment of area describes the bending of beams.
Peter10
Hi everyone!
Please help, I have spent some considerable time to understand the two concepts and still this is nagging at me... I am relating to Structural Engineering, just to let you know guys. My question is ..
Moment of inertia is about distribution of mass, the further away from the axis the higher the resistance to applied moment ( I believe I know the concepts of angular acceleration and etc.). Likewise in case of Elastic Section Modulus if the distribution of area of section is larger away from the axis the resistance to elastic deformation is greater... So in terms of Structural Engineering what is the difference between the two? I know that moment of inertia is related to mass (althou it is in cm^4 which is brings another question, why is it not in kg?), but as in practical sense why do we need one or the other to determine the strength of the beam, let's say up to elastic limit?
Peter10 said:
Hi everyone!
You are confusing two different concepts, namely the second moment of area and the mass moment of inertia, which are unfortunately and inaccurately known by the grab-all term "moment of inertia".
Let's take the "mass moment of inertia" of a body first.
We know from Newton's laws of motion that it takes a certain applied effort to change the motion of a body. For bodies in rectilinear motion, the equation F = ma describes how the acceleration of a body of mass m will change when a certain external force F is applied.
For bodies in rotational motion, the corresponding equation is T = J α, where J is the mass moment of inertia of the body (and which has units of ML2) and α is the angular acceleration (units of radians per second2) produced by the applied torque T (units of force times distance, or M × L × T-2 × L = ML2T-2). The mass moment of inertia J is an intrinsic property of the body, the value of which is influenced by the distribution of mass about the center of gravity.
The mass moment of inertia is used to calculate the dynamics of bodies undergoing motion.
The other moment of inertia, the second moment of area, is the one which is most commonly encountered in structural engineering. The second moment of area, usually denoted as I, arises from studying the bending of beams. The bending stress σ in a beam is given by the equation σ = M y / I, where M is the applied bending moment, y is the distance from the neutral axis to where the bending stress is sought, and I is the second moment of area of the cross section of the beam. This inertia is roughly analogous to J in that it describes the distribution of section area about the centroid of the section. The units of I are A × L2 (compare the units of J = M × L2), which is why tables of structural properties have units like cm4.
In beam analysis, the maximum bending stress is encountered at the outer fiber of the beam, which is located at the greatest distance from the neutral axis.
Thus for a given structural section, I can be calculated and y is known from the geometry, so the bending stress formula can be re-written as σ = M / SM, where SM is the section modulus of the beam cross section and SM = I / y (units of L3. By knowing the section modulus of a beam at a given location, it is thus a simple calculation to find out how much bending moment will produce a given level of bending stress. If you take a beam with a limiting elastic stress σ, then the maximum bending moment is M = σ × SM.
Thank you!
Related to Difference between second moment of area and section modulus
What is the second moment of area?
The second moment of area, also known as the moment of inertia, is a measure of an object's resistance to bending. It is a mathematical property that describes an object's cross-sectional shape and the distribution of its mass around an axis.
What is the section modulus?
The section modulus is a measure of an object's resistance to bending stress. It is calculated by dividing the second moment of area by the distance from the neutral axis to the outermost point of the cross-section. It is used to determine the strength and stiffness of a structural member.
What is the difference between second moment of area and section modulus?
The second moment of area is a property of an object's cross-sectional shape, while the section modulus is a measure of its resistance to bending stress. The main difference is that the second moment of area is a geometric property, while the section modulus takes into account the material's properties as well.
How are second moment of area and section modulus related?
The second moment of area and section modulus are mathematically related, as the section modulus is calculated by dividing the second moment of area by the distance from the neutral axis. This relationship helps to determine the maximum bending stress that a structural member can withstand.
Why are second moment of area and section modulus important in engineering?
Both the second moment of area and section modulus are important in engineering as they help to determine the strength and stiffness of a structural member. These properties are crucial in designing structures that can withstand bending and torsional forces, ensuring the safety and durability of the structure.
  • Mechanical Engineering
  • General Engineering
18K
