Difference between solid-state, semiconductor and gas lasers
In summary, the main difference between solid-state, semiconductor, and gas lasers lies in how the amplification is achieved. While all lasers use energy state inversion, the methods for achieving this differ. Semiconductor lasers use a P-N junction and electric current to create the necessary electron and hole population for inversion, while gas lasers rely on excitation of gas molecules. Solid-state and dye lasers also use optical pumping to achieve inversion. Generally, electrical excitation is more efficient than optical pumping.
says
594
What is the difference between solid-state (SS), semiconductor and gas lasers?
I know SS lasers are optically pumped (generally), while semiconductor and gas lasers are electrically pumped (laser diode). The active mediums are also unique.
Beyond this though, I'm not entirely sure about any other differences. I've read about efficiencies for example, but usually it says, 'this laser is more efficient than this laser, or this laser is more efficient than that laser.' Nothing that gives general information, i.e. 'SS lasers are less efficient than semiconductor lasers'.
You as a very broad question. The fundamental differences are in how the amplification is achieved. All the lasers use some form of energy state inversion... where in a quantized energy system there are more elements in an excited state than in a lower energy state. There also needs to be sufficient lifetime of the inverted system for stimulated emission to yield amplification and of course coupling between the systems in the form of the light transmitted.
For semiconductors it is a matter of electrons and holes existing the semiconductor crystal in sufficient population. The existence of the free electrons and holes vs the ground state of electrons filling the holes is the inversion state. This is typically achieved by passing current through a P-N junction, the holes in the P type and electrons in the N type semiconductor will flow toward the junction. The junction itself is the intrinsic material so both holes and free electrons require extra energy to exist. The voltage of the current flow across the junction interfaces provide that energy. You also need the intrinsic layer to be optically clear in the frequencies corresponding to the pair annihilation energy.
For gas lasers you simply use excitation of the gas molecules electron orbitals. Its the same mechanism as your gas discharge lamps, such as neon lights or mecury florescent lamps. The difficulty is in achieving the inversion. Simply pumping current through will typically do it since the pumping is too random. You can achieve pulsed lasing this way but the gas then needs to cool down before subsequent excitation. The HeNe lasers take advantage of selective interaction between the helium and neon atoms. The electrons pump up the helium into a high excited density (though not an inversion) but then the helium can transfer energy to the neon in a way that maintains continuous inversion. (like a pump pushing water up to maintain a water fall.)
Solid state and dye lasers work on the same mechanism except they must be pumped optically (and at a higher frequency than the lasing freq.)
Now you can pump gas, semiconductor (in principle), and solid state laser using light. Typically optical pumping is less efficient than electrical excitation. There's one other class I know of and that's chemically pumped lasers. I believe one of the SDI developed military weapons lasers was based on reacting hydrogen and fluorine producing excited HFl gas in an excited state which then can lase.
Likes jim mcnamara
Related to Difference between solid-state, semiconductor and gas lasers
1. What is the difference between solid-state, semiconductor, and gas lasers?
The main difference between solid-state, semiconductor, and gas lasers lies in the type of medium used to generate the laser beam. Solid-state lasers use a solid material, such as crystals or glass, as the medium. Semiconductor lasers use a semiconductor material, such as gallium arsenide, as the medium. Gas lasers use a gas, such as helium or carbon dioxide, as the medium.
2. Which type of laser is most commonly used?
Semiconductor lasers are the most commonly used type of laser, as they are compact, efficient, and have a wide range of applications. They are also the most cost-effective option for many applications.
3. How do the properties of the medium affect the performance of the laser?
The properties of the medium, such as its energy levels and ability to amplify light, determine the wavelength and intensity of the laser beam. This, in turn, affects the applications for which the laser can be used. For example, gas lasers are commonly used for cutting and welding materials, while solid-state lasers are used for precision cutting and engraving.
4. Are there any advantages of one type of laser over the others?
Each type of laser has its own advantages and disadvantages. Solid-state lasers have a longer lifetime and are more stable, while semiconductor lasers are smaller and more energy-efficient. Gas lasers are powerful and can produce high-intensity beams. The choice of laser type depends on the specific application and desired performance.
5. Can different types of lasers be used together?
Yes, it is possible to combine different types of lasers to achieve specific results. For example, a semiconductor laser can be used to pump a solid-state laser to create a more powerful beam. Additionally, multiple lasers of the same type can be combined to increase the overall power output.
  • Atomic and Condensed Matter
16K
