Difference between spacetime and the gravitational field?
In summary, the conversation discusses the relationship between spacetime and the gravitational quantum field, with the question of whether they are separate entities or part of a unified system. The concept of fields and point particles is also brought up, with the idea that they may be more fundamental depending on the model. The potential impact of these questions on unifying quantum field theory and general relativity is also mentioned.
R. E. Nettleton
Are spacetime and the gravitational quantum field (still hypothetical) separate entities? Would the gravitational field be more fundamental, one of the various entities from which spacetime as a whole is composed?
Gravitons, which are believed to transmit the force of gravity, would surely be excitations of the gravitational field - however, gravity arises from the curvature of spacetime. If separate, would the curvature of spacetime simultaneously excite the gravitational field, or vice versa?
Fields are defined by variables across different points in space and time, so, if the two were the same system, would the gravitational field not define itself (paradoxical)?
Are there any theoretical answers to these questions; if not, would the answers be vital in unifying QFT and GR?
Astronomy news on Phys.org
They are different models of gravity. They may be considered 'unified' entities when somebody figures out to combine GR and quantum theory of gravity.
based on past discussions in these forums nobody knows whether space and time are quantized or continuous...and some research papers claim that distinction is meaningless anyway. Do we need to worry about increments of Planck length or Planck time...depends on the model and scales of interest.
QUOTE="R. E. Nettleton, post: 5380813, member: 574297"]If separate, would the curvature of spacetime simultaneously excite the gravitational field, or vice versa?[/QUOTE]
Yes. Depends on your model. It is interesting that we model via field theories [as you posted] which assign continuous values to points in time and space, yet when we go to measure entities, what we find are point particle' interactions, of immessurably small dimension. In other words, the QFT of the Standard Model of particle physics, which so far excludes gravity,is a model of POINT like interactions. It is modeled on fixed spacetime backgrounds, not the dynamic 'changing, evolving] spacetimes of GR.
I'm unsure if there is a consensus on whether fields or point particles are more fundamental. My own view is that depends on your model. If the photon [or virtual photon if you like] is the particle of the electromagnetic field, then the graviton is the particle of the gravitational field. Also keep in mind most of these models are approximations: for example the electromagnetic field varying as 1/r2 runs into problems as one approaches small distances, as r approaches zero.
We use quanta because that is what we measure. Max Planck discovered physical action at small scales takes place in discrete steps, not continuous ones...hence the 'h' Planck's constant. Action at the sub atomic scale is quantized...that is we see interactions as multiples of 'h'.
Related to Difference between spacetime and the gravitational field?
1. What is spacetime?
Spacetime is a conceptual framework that combines space and time into a single entity. It is a fundamental concept in the theory of relativity and is used to describe the physical universe.
2. What is the gravitational field?
The gravitational field is a region of space in which objects with mass experience a force of attraction. It is created by massive objects like planets, stars, and galaxies, and its strength depends on the mass and distance of these objects.
3. How are spacetime and the gravitational field related?
Spacetime and the gravitational field are closely related in the theory of general relativity. According to this theory, the presence of mass and energy causes a curvature in spacetime, which in turn affects the gravitational field. This means that the gravitational field is a manifestation of the curvature of spacetime.
4. What is the main difference between spacetime and the gravitational field?
The main difference between spacetime and the gravitational field is that spacetime is a conceptual framework, while the gravitational field is a physical entity. Spacetime is used to describe the fabric of the universe, while the gravitational field is a force that acts on objects within this fabric.
5. How does the understanding of spacetime and the gravitational field impact our understanding of the universe?
The understanding of spacetime and the gravitational field has greatly impacted our understanding of the universe. It has led to the development of the theory of general relativity, which has revolutionized our understanding of gravity and the behavior of objects in the universe. It has also helped us to better understand the structure of the universe and its evolution over time.
  • Beyond the Standard Models
  • Quantum Interpretations and Foundations
