Difference between systems engineering and regular engineering?
In summary: If you like looking at the big picture and seeing how all the pieces fit together, then systems engineering would be a better fit.In summary, the conversation discusses the differences between electronic engineering and electronic systems engineering. The main distinction is that systems engineering focuses on the big picture and piecing together technical aspects, while electronic engineering is more technical and focuses on the "nuts and bolts." The degree names may vary depending on the school and their specific course work. It is important to research and compare the course work of different schools to determine the best fit for your interests and career goals.
JyN
28
I was looking through a list of engineering degrees offered http://www.engineerscanada.ca/e/pr_programs1.cfm and i noticed that almost all of them are XXXX engineering.
However, if you go down to the university of regina (my school) all the degrees are XXXX systems engineering.
I am currently a first year student in engineering, and will probably specialize in electronic systems engineering. so, what is the difference specifically between electronic SYSTEMS engineering, and just electronic engineering?
And what are the differences in general?
Finally, is one of them a superior degree to the other?? or are they essentially the same thing?
bump..
My best suggestion is to compare the course work of your school's degrees to other schools. In some cases it is a naming decision by the college, while other times it is a different degree by significant amounts of course work.
In this case I would image it's just a different naming scheme.
Systems engineering is different than "regular" engineering.
Systems engineering deals with projects from a larger perspective, aka "the big picture." Their job is to efficiently and smoothly piece together all technical engineering aspects of a program.
So, those two programs you cited are different. If you're more technical and want to work on the "nuts and bolts," then do electronics engineering.
I can provide a response to the question of the difference between systems engineering and regular engineering.
Systems engineering is a interdisciplinary approach to engineering that focuses on the design, development, and management of complex systems. It involves the integration of various disciplines such as mechanical, electrical, and software engineering to create a holistic and efficient system. Systems engineering also involves considering the entire life cycle of the system, from conception to retirement.
On the other hand, regular engineering refers to the traditional approach of focusing on one specific discipline, such as mechanical, electrical, or chemical engineering. It involves the application of scientific and mathematical principles to design and develop products, processes, or systems.
In the context of your specific question, electronic systems engineering would involve the application of systems engineering principles to the design and development of electronic systems, while electronic engineering would focus more on the specific principles and techniques of electronic devices and circuits.
In general, systems engineering is seen as a more comprehensive and interdisciplinary approach, while regular engineering is more focused on a specific discipline. However, both have their own strengths and can be considered equally important in the field of engineering.
There is no clear answer as to whether one degree is superior to the other. It ultimately depends on your interests and career goals. If you are interested in working on complex and integrated systems, systems engineering may be a better fit for you. If you are more interested in the technical aspects of a specific discipline, regular engineering may be a better choice. Both degrees can lead to successful and fulfilling careers in the engineering field.
FAQ: Difference between systems engineering and regular engineering?
What is the difference between systems engineering and regular engineering?
Systems engineering is a multidisciplinary approach to designing and managing complex systems, while regular engineering focuses on designing and developing individual components or subsystems.
What types of systems are typically involved in systems engineering?
Systems engineering can be applied to a wide range of systems, including software systems, hardware systems, mechanical systems, and social systems.
How does systems engineering differ from traditional engineering methods?
Systems engineering takes a holistic approach to problem-solving, considering the entire system and its environment, rather than focusing on individual parts. It also emphasizes the integration and coordination of different subsystems.
What skills are required for a career in systems engineering?
In addition to technical skills, systems engineers also need strong communication, project management, and systems thinking skills. They must also be able to work well in teams and have a broad understanding of various engineering disciplines.
What are the benefits of using systems engineering in a project?
Systems engineering can help ensure that all aspects of a project are considered and integrated, leading to more efficient and effective solutions. It also promotes collaboration and communication among team members and stakeholders, leading to better outcomes.
