Difference between Tangent Plane and Linearization
In summary, the difference between a tangent line and a 2D linearization is that a tangent line is a predictive equation based on a tangent line used to approximate the value of a function in 2 dimensions, while a 3D linearization is a predictive equation based on a tangent plane used to approximate a function in 3 dimensions. Both concepts involve finding the tangent at a specific point and using it to approximate the function. The only difference is that the tangent line is used for 2D functions and the tangent plane is used for 3D functions. This concept was discussed in the "Homework: Calculus and Beyond" forum, and it is important to not post the same question multiple times.
newyorkcity
28
What is the difference?
According to my text...
Tangent Plane:
z-z0=fx(x0,y0)(x-x0) + fy(x0,y0)(y-y0)
Linearization:
L(x,y) = f(a,b) + fx(a,b)(x-a) + fy(a,b)(y-b)
Tangent Plane:
Linearization:
Well, think back to 2-dimensions.
What is the difference between a tangent line and a 2d linearization?
It is exactly the same concept, except brought into R3. Just as a 2-d linearization is a predictive equation based on a tangent line which is used to approximate the value of a function, a 3-d linearization is a predictive equation based on a tangent plane which is used to approximate a function.
Looking back at the text, I just missed the relationship between (a,b), (x0,y0), and (x,y). To clarify, the 'Tangent Plane' equation is used to find the tangent plane at a point P(x0,y0,z0). The 'Linearization' equation yields the linear approximation of f(x,y) at (a,b). Thanks for your help.
Yes, just as the "linearization" of y= f(x) gives the tangent line to the curve, so the "linearization" of z= f(x,y) gives the tangent plane to the surface. The only difference is that when you talk about the "linearization" you are thinking of the functions and when you talk about the tangent plane you are thinking about their graphs.
This same question was asked in "Homework: Caculus and Beyond" so I am combining the two threads. newyorkcity, do NOT post the same question more than once.
Related to Difference between Tangent Plane and Linearization
1. What is the difference between tangent plane and linearization?
The tangent plane is a two-dimensional surface that touches a three-dimensional surface at a single point, while linearization is the process of approximating a nonlinear function with a linear function at a specific point.
2. How are tangent planes and linearization used in real-world applications?
Tangent planes are used in calculus to find the slope of a curve at a specific point, while linearization is used in engineering and physics to approximate complex systems and make calculations easier.
3. Can you give an example of when tangent planes and linearization are used together?
One example is in computer graphics, where tangent planes are used to create smooth surfaces, and linearization is used to approximate lighting and shading effects on those surfaces.
4. How do you find the equation of a tangent plane and a linearization?
The equation of a tangent plane can be found by taking the partial derivatives of a function at a specific point, while the equation of a linearization can be found using the point-slope form of a line with the slope being the derivative of the function at that point.
5. Is there a limit to how accurate linearization can be?
Yes, linearization is only an approximation and will become less accurate as you move further away from the specific point it was calculated at. The accuracy also depends on the complexity of the function being approximated.
  • Differential Equations
