Difference between vector and parametric differentiation
In summary, parametric equations and vector equations may have similar components, but they serve different purposes and are calculated using different formulas. Parametric equations describe a curve in the xy-plane while vector equations represent the velocity of a point along that curve. The differentiation of these equations also utilizes different formulas, with parametric differentiation being defined as the ratio of derivatives and vector differentiation being defined as the vector of derivatives.
Mr Davis 97
1,462
44
This might seem like a naive question to ask, but a full explanation of why these two concepts are different would be welcome. I am confused because parametric equations are ##y = 8t^2## and ##x = 5t##, but at the same time, these two equations can describe the ##x## and ##y## components of a vector. Parametric differentiation is defined as ##\frac{\mathrm{d} y}{\mathrm{d} x} = \frac{\frac{\mathrm{d} y}{\mathrm{d} t}}{\frac{\mathrm{d} x}{\mathrm{d} t}}##, while vector differentiation is defined as ##\frac{\mathrm{d} \vec{r}}{\mathrm{d} t} = \left \langle \frac{\mathrm{d} x}{\mathrm{d} t}, \frac{\mathrm{d} y}{\mathrm{d} t} \right \rangle##
Mathematics news on Phys.org
Mr Davis 97 said:
parametric equations are y=8t2y = 8t^2 and x=5tx = 5t, but at the same time, these two equations can describe the xx and yy components of a vector.
Not exactly. As t varies, the coordinates describe a curve in the xy -plane.
Mr Davis 97 said:
Parametric differentiation is defined as dydx=dydtdxdt\frac{\mathrm{d} y}{\mathrm{d} x} = \frac{\frac{\mathrm{d} y}{\mathrm{d} t}}{\frac{\mathrm{d} x}{\mathrm{d} t}}, while vector differentiation is defined as dr⃗ dt=⟨dxdt,dydt⟩\frac{\mathrm{d} \vec{r}}{\mathrm{d} t} = \left \langle \frac{\mathrm{d} x}{\mathrm{d} t}, \frac{\mathrm{d} y}{\mathrm{d} t} \right \rangle
If we assume that t stands for time, [itex]\frac{d\vec{r}}{dt} [/itex] represents the velocity at a give time (velocity has a magnitude and a direction). This quantity is fundamental in classical differential geometry.
If you eliminate the parameter ##t## and get ##y## in terms of ##x## then ##\frac{dy}{dx}## represents the slope of the curve. That is what you are calculating when you do$$
\frac{dy}{dx} =\frac{\frac{dy}{dt}}{\frac{dx}{dt}}$$That is not the same thing as ##\frac{dr}{dt}## which is the velocity the point moves along the curve as a function of ##t##. Different things, different formulas.
Related to Difference between vector and parametric differentiation
What is the difference between vector differentiation and parametric differentiation?
Vector differentiation is a type of differentiation where the derivative of a vector function is taken with respect to a single variable. Parametric differentiation, on the other hand, is a type of differentiation where the derivative of a parametric function is taken with respect to a parameter. In simpler terms, vector differentiation deals with functions that have both magnitude and direction, while parametric differentiation deals with functions that have multiple variables that are dependent on a parameter.
How are the derivatives of vector and parametric functions calculated?
The derivative of a vector function is calculated by taking the derivatives of each component of the vector and forming a new vector with these derivatives. The derivative of a parametric function is calculated by using the chain rule, where the derivative of each variable is multiplied by the derivative of the parameter with respect to the variable.
What are the applications of vector and parametric differentiation in science?
Vector differentiation is commonly used in physics and engineering to analyze the motion of objects in terms of their velocity and acceleration. Parametric differentiation is useful in various fields such as statistics, economics, and biology to model relationships between variables and study their changes over time.
Can vector and parametric differentiation be used interchangeably?
No, vector differentiation and parametric differentiation are two different methods that cannot be used interchangeably. While vector differentiation is used for vector functions, parametric differentiation is used for parametric functions. It is important to understand which method is appropriate for the given function in order to accurately calculate derivatives.
Are there any similarities between vector and parametric differentiation?
Yes, both vector and parametric differentiation involve taking derivatives of functions. They also both use the chain rule to calculate derivatives. However, the main difference lies in the types of functions they are used for and the variables involved in the differentiation process.
11K
10K
  • General Math
