Difference between wirewound resistor and inductor
In summary, the conversation discusses the difference in construction between a wirewound resistor and an inductor. Both use a coil loop, but behave differently due to their varying functions. The coil in a wirewound resistor induces a magnetic field, while an inductor creates a magnetic field that impedes current flow. The conversation also mentions that both components have parasitic resistance, inductance, and capacitance which can affect circuit design. Additionally, it is mentioned that metal film resistors and power inductors can be designed with low resistance and inductance respectively. The conversation concludes with a mention of bifilar wound resistors and their use in high frequency applications.
mark g
Hi.
I am looking to understand the difference primarily in construction between a wirewound resistor and an inductor. Both are formed using a coil loop but are clearly behaving differently. Does the coil in a wirewound resistor induce a magnetic field??
Thanks,
Mark.
I'm no expert, but I can give you a very basic starting point. A resistor restricts voltage just because it doesn't conduct electricity very well. An inductor creates a magnetic field that impedes current flow. That's not quite exactly how it goes, but it's the best that I have to offer. Someone else will help you shortly.
Any wire wound resistor has Resistance and Inductance. So does a wound Inductor. They are usually designed so that the Inductance of a WW Resistor is negligible compared with the Resistance and the Resistance of and Inductor is negligible, compared with its Inductance.
When dealing with high frequencies or high powers, the parasitic Resistance and Inductances can be very relevant and circuit design needs to take them into account.
Metal film resistors can be made that have very low inductance and Power Inductors can be made with thick wire and appropriate core material, giving low Resistance.
Whilst we are at it, those components will also have parasitic Capacitance, which can also be a nuisance.
Likes Danger
mark g said:
Hi.
Thanks,
Mark.
There is a difference in construction. To wind a resistor with very low inductance, take your (insulated) resistance wire and double it back on itself, then wind the coil with the doubled wire. The current will flow around the coil in one direction and then back in the opposite direction, and the magnetic fields cancel.
Likes Danger
Bifilar wound resistors - good point. The ultimate is metal film without the spiral groves that are normally used to get the wanted value. Very expensive but essential when you work at UHF and above.
FAQ: Difference between wirewound resistor and inductor
What is the main difference between a wirewound resistor and an inductor?
A wirewound resistor is a type of resistor that uses a long, thin wire wrapped around a core material to create resistance. An inductor, on the other hand, is a passive electronic component that stores energy in the form of a magnetic field. The main difference between the two is their function - a resistor is used to limit the flow of electric current, while an inductor is used to store energy.
How are wirewound resistors and inductors constructed?
Wirewound resistors are typically made by winding a wire made of a resistive material, such as nichrome, around a ceramic or fiberglass core. The length and thickness of the wire determine the resistance value. Inductors are typically constructed by winding a wire around a core made of a ferromagnetic material, such as iron or ferrite. The number of turns and the core material determine the inductance value.
Can a wirewound resistor be used as an inductor?
No, a wirewound resistor cannot be used as an inductor. While both components use wire winding, they serve different purposes and have different constructions. The wire used in a resistor is designed to have a high resistance, while the wire used in an inductor is designed to have low resistance and high inductance.
What are the similarities between wirewound resistors and inductors?
Both wirewound resistors and inductors use wire winding as part of their construction. They are both passive electronic components that can be found in electronic circuits. They also both have the ability to dissipate heat, although this is not a primary function for inductors.
How do wirewound resistors and inductors affect the performance of a circuit?
Wirewound resistors and inductors can both affect the performance of a circuit in different ways. Resistors can limit the flow of current and help regulate voltage levels, while inductors can store energy and help filter out unwanted frequencies. The values of resistors and inductors can also affect the overall impedance of a circuit, which can impact the flow of current and the behavior of the circuit.
