Difference conservative and non-conversative force
In summary, a conservative force is a type of force that does not depend on the path taken by an object and only depends on its starting and ending positions. An example of a conservative force is gravity, which is why potential energy due to gravity is defined as -mgh. On the other hand, a non-conservative force is a type of force that does depend on the path taken by an object, such as friction. The work done by non-conservative forces decreases an object's total mechanical energy, while conservative forces do not change it. This is why objects eventually come to a stop due to the presence of non-conservative forces.
Blockade
68
I don't understand what is meant by a force being conservative. Is it where the force moves in an easier to calculate manner with straight lines; whereas, non-conservative moves in a curves where you'd have to use integration?
Are you familiar with the concept of work in physics? A force is conservative if the work done in moving a particle between two points does not depend on the path taken.
FAQ: Difference conservative and non-conversative force
What is the definition of a conservative force?
A conservative force is a type of force that, when applied to an object, does not depend on the path taken by the object. This means that the work done by the force is independent of the path and only depends on the starting and ending positions of the object.
What is an example of a conservative force?
An example of a conservative force is gravity. Regardless of the path taken by an object, the work done by gravity is only dependent on the starting and ending positions of the object. This is why the potential energy due to gravity is defined as -mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object above the ground.
What is the definition of a non-conservative force?
A non-conservative force is a type of force that, when applied to an object, depends on the path taken by the object. This means that the work done by the force is not independent of the path and can vary depending on the path taken by the object.
What is an example of a non-conservative force?
An example of a non-conservative force is friction. The work done by friction depends on the distance traveled by an object, which means that the path taken by the object affects the work done by friction. This is why the work-energy theorem states that the work done by non-conservative forces, such as friction, decreases the total mechanical energy of an object.
How do conservative and non-conservative forces affect an object's total mechanical energy?
Conservative forces do not change an object's total mechanical energy, as they only transfer energy between potential and kinetic forms. Non-conservative forces, on the other hand, decrease an object's total mechanical energy as they transfer energy to other forms, such as heat or sound. This is why objects eventually come to a stop due to the presence of non-conservative forces like friction.
13K
