Difference of two squares considered to be a quadratic
In summary, "Quadratic" refers to a polynomial of degree 2, and x^2- 4 is an example of a quadratic while x^4- 4 is not. The "difference of two squares" can be easily factored, as shown by (x- 2)(x+ 2) for x^2- 4 and (x^2- 2)(x^2+ 2) for x^4- 4. Polynomials of degree higher than 5 are called quintics, but there is no specific terminology for polynomials of degree higher than 5.
vanmaiden
102
is an expression that is a difference of two squares considered to be a quadratic. For example, would x2 - 4 be a quadratic? What about x4 - 4?
Ax2 + Bx + C
I know we can factor a DOTS into two binomials like a quadratic in the for Ax2 + Bx + C, but I wanted to be clear on what a DOTS was relative to a quadratic equation.
"Quadratic" simply means "a polynomial of degree 2". Yes, [itex]x^2- 4[/itex] is quadratic, no, [itex]x^4- 4[/itex] is not. The importance of the "difference of two squares" is, as you say, that it can be easily factored: the quadratic [itex]x^2- 4[/itex] can be factored into two linear factors: [itex](x- 2)(x+ 2)[/itex], the quartic [itex]x^4- 4[/itex] can be factored into two quadratic terms: [itex](x^2- 2)(x^2+ 2)[/itex].
So, to be clear, x4 - 4 is a quartic. Is there a special name given to something like x6 - 4?
I haven't seen any terminology for polynomials higher than degree five, and these are called quintics.
Interesting. I'll be on the lookout :smile:
FAQ: Difference of two squares considered to be a quadratic
What is the difference of two squares?
The difference of two squares is a mathematical expression in the form of a2 - b2, where a and b are numbers or variables. It can also be written as (a+b)(a-b).
How is the difference of two squares related to quadratics?
The difference of two squares is considered to be a quadratic because it can be factored into two linear expressions, making it a quadratic equation. This can be helpful in solving quadratic equations or graphing quadratic functions.
What is the significance of the difference of two squares in algebra?
The difference of two squares is significant in algebra because it is a commonly used form in factoring quadratic equations. It can also help in simplifying expressions and solving equations.
How can the difference of two squares be applied in real life?
The difference of two squares can be applied in real life in various fields such as engineering, physics, and finance. For example, it can be used to find the distance between two points in a coordinate plane or to calculate the difference in values between two variables in a financial equation.
Can the difference of two squares be expanded to more than two terms?
No, the difference of two squares is a specific mathematical expression that involves only two terms. Expanding it to more than two terms would change the equation and it would no longer be considered a difference of two squares.
