Different classical limits of quantum mechanics
In summary, there are multiple ways to reduce the equations of special relativity (aka Lorentz Transformations) to the equations of Newtonian mechanics (aka Galilean Transformations).
spaghetti3451
1,344
34
There is only one way to reduce the equations of special relativity (aka Lorentz Transformations) to the equations of Newtonian mechanics (aka Galilean Transformations).
In light of the above, why are there multiple ways to reduce quantum-mechanical equations of motion into classical equations of motion? For example, you could either take the Planck's constant to zero, or take the quantum numbers to infinity to reduce to the classical behaviour.
They two approaches are pretty much the same thing: we're considering the limit as the spacing between adjacent energy levels approaches zero.
I could as easily say that there are multiple ways of reducing the equations of SR to Newtonian mechanics: take ##c## to be infinite, take ##v/c## to be zero, take ##\gamma## to be one.
Likes jerromyjon and bhobba
Is it always true in physics that a limiting theory can be derived from a general theory by taking the limit of one unique parameter?
Did you not read Nugatory's post? He provides a counterexample right there!
Likes bhobba
Nugatory said:
take v/c to be zero
I had to think a minute about that one but the others are obvious.
Well, the parameters ##c##, ##\frac{v}{c}##, and ##\gamma## are all related to each other, as these parameters are simply various arithmetic combinations of ##v## and ##c##. That, I understand.
However, what I was actually wanting to ask is if there are two or more parameters, ##\textit{which cannot be related to each other in any which way}##, which still produce the special limit of ##\textit{some}## general theory.
If you can reach the same limit by taking two different parameters to some limit, are not the two parameters related?
Yes, they must be! It's clear to me now!
I was wondering if there is an introduction to quantum mechanics that follows naturally from classical mechanics.
In classical mechanics, there are three equivalent formalisms: Newtonian, Lagrangian, and Hamiltonian.
In quantum mechanics, there are also three equivalent formalisms: Schrodinger, Heisenberg, and Feynman.
It turns out that Schrodinger and Heisenberg formalisms are differential and integral forms of the same underlying principle, and generalise Hamiltonian mechanics.
Furthermore, Feynman's path integral formalism generalise Lagrangian mechanics.
Is there no quantum- mechanical generalisation of Newton's laws of motion?
Also, is there some textbook or resource that brings out the relationship of the Schrodinger and Heisenberg formalisms to Hamiltonian mechanics elegantly and in comprehensive detail: for instance, I understand that variables generalise to operators and Poisson brackets generalise to Lie brackets, but I don't see how eigenvalues arise in quantum mechanics from classical mechanics.
You are seeing it backwards. Quantum mechanics don't arises from classical mechanics, at most is the other way around.
And yes, there is a quantum mechanics-like description of classical mechanics(perhaps its more a description of classical statistical mechanics), but it is not a generalization but just a way to describe it with a different mathematics .
Related to Different classical limits of quantum mechanics
1. What is the classical limit of quantum mechanics?
The classical limit of quantum mechanics is the theoretical boundary between the quantum world and the classical world. It is the point at which quantum effects become negligible and classical mechanics can accurately describe the behavior of a system.
2. What are the different classical limits of quantum mechanics?
There are two main classical limits of quantum mechanics: the macroscopic limit and the high-energy limit. The macroscopic limit refers to systems with a large number of particles, where quantum effects become negligible and classical mechanics can accurately describe their behavior. The high-energy limit refers to particles with very high energies, where relativistic effects become significant and classical mechanics is no longer applicable.
3. How is the classical limit of quantum mechanics related to the uncertainty principle?
The uncertainty principle states that it is impossible to know both the position and momentum of a particle with absolute precision. In the classical limit, where quantum effects are negligible, this principle does not apply and the position and momentum of a particle can be known with arbitrary precision.
4. Can the classical limit of quantum mechanics be observed in real-life systems?
Yes, the classical limit of quantum mechanics can be observed in many real-life systems. For example, the behavior of macroscopic objects such as a baseball or a car can be accurately described using classical mechanics. Similarly, particles with very high energies, such as those in a particle accelerator, can be described using classical mechanics.
5. Why is it important to understand the classical limits of quantum mechanics?
Understanding the classical limits of quantum mechanics is important because it helps us to better understand the relationship between the quantum world and the classical world. It also allows us to accurately describe and predict the behavior of different systems, from microscopic particles to macroscopic objects, in various conditions. Additionally, knowledge of the classical limits can aid in the development of new technologies, such as quantum computers, which rely on the principles of quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
