Different Dilution factors for the normalizator
In summary, the conversation discusses the use of B actin as a normalizing agent in a western blot and the issue of using different dilution factors for the B actin antibody. The expert advises against using different dilutions and emphasizes the importance of standardization in the experiment. They also suggest seeking guidance from someone with expertise in the technique to avoid wasting samples and obtaining useless data. The conversation concludes with the speaker thanking the expert for their advice.
sotellme
75
I am looking for some ideas about this one. I use B actin as the normalizator in my western blot. i use different dilution factors of the B actin antibody. For some samples i use 500X and for others i use 1000X. I wonder when i normalize my samples and calculate the relative expression levels for the different protein targets should i take the different dilution factors of the B actin in account or should i pretend that they have the same dilution factor?
Thanks.
Biology news on Phys.org
You shouldn't use different dilutions at all. There is no conversion factor you can use, because antibody binding is not linear, so if you've used different dilutions of antibody, that's going to be useless to normalize your samples. Why are you varying your antibody dilutions in the middle of an experiment? If you're changing your technique, nothing is standardized.
Before you run any more experimental samples, sit down with someone who KNOWS this technique and plan out what you need to do and work with them, otherwise you're going to just keep wasting samples and money and will have completely useless data. If nobody in your lab knows how to do this, plenty of people do Westerns all day, every day; visit someone else's lab to learn. It's a lot cheaper to pay the travel expenses to visit another lab than it is to keep throwing away samples by making mistakes anyone who knows the technique could have stopped you from doing in the first place.
Dear Moonbear!
You saved my life! :smile: actually this is the idea of my advisor. He told me to use different dilution factors. I need to have a talk with him. Thank you! :approve:
FAQ: Different Dilution factors for the normalizator
1. What is the purpose of using different dilution factors for the normalizator?
Different dilution factors are used to ensure that the concentration of the normalizator is within the range that can be accurately measured. This helps to avoid any saturation or dilution effects that could affect the accuracy of the results.
2. How do you determine which dilution factor to use for the normalizator?
The dilution factor is typically determined based on the concentration of the normalizator and the sensitivity of the measuring equipment. It is important to use a dilution factor that will result in a concentration within the linear range of the equipment.
3. Can you use the same dilution factor for all types of normalizators?
No, the dilution factor may vary depending on the type of normalizator being used. Different normalizators may have different concentrations and sensitivities, so it is important to determine the appropriate dilution factor for each type.
4. Is it possible to use a dilution factor that is too high or too low?
Yes, using a dilution factor that is too high or too low can affect the accuracy of the results. If the dilution factor is too high, the concentration of the normalizator may fall below the detection limit of the equipment. If the dilution factor is too low, the concentration may be outside of the linear range of the equipment.
5. How do you calculate the dilution factor for the normalizator?
The dilution factor can be calculated by dividing the initial concentration of the normalizator by the desired concentration. For example, if the initial concentration is 100 mg/L and the desired concentration is 10 mg/L, the dilution factor would be 100/10 = 10.
15K
12K
24K
