NooDota
- 68
In a physical, or a simple pendulum, to get the velocity of the pendulum at some point, we apply the kinetic energy theory, and use m*g*h to calculate the work done by weight, I'm wondering if there are any other ways to calculate the work? I don't care how complicated it is, I'm just curious. Can I use W = F.d?
D in this case would be the circular sector, correct? I think there's some law to calculate that, I can't recall exactly, it's something like 1/2 * r * omega^2
But how would I get the weight component?
Here's a sample problem (I translated it myself, so the notation may not be fine), the first 3 questions are irrelevant, it's the 4th one where you use W=m*g*h
A physical pendulum is made up by a rod with neglected mass which has a length of 1m, carrying on its upper end a particle with a mass of 0.2kg, and its on lower end, a particle with a mass of 0.6kg, the rod oscillates around a horizontal axis going through the half of it (center of mass).
1. Find the period for small oscillations.
2. Calculate the length of the simple pendulum that has the same period as the previous pendulum.
3. Find the period of the pendulum if it were to oscillate with an amplitude of 0.4rad
4. We sway the rod from its balance point to an angle of 60 degrees and leave it with zero initial velocity.
A. Find the velocity of the pendulum the moment it goes through the balance point.
I'm not interested in a solution, all I want to know if it's possible to calculate the work of the weight force without m*g*h*, or even finding the velocity without resorting to the kinetic energy theorem.
Thanks
