Different time accumulated on clocks
In summary, the conversation discusses the concepts of length contraction and time dilation in relation to an observer on Earth and a person on a rocket traveling at near the speed of light. The question arises as to why the time accumulated on the rocket's clock is different from that on Earth's clock, even though the length remains the same upon the rocket's return. The answer is that motion is relative and the effects of length contraction and time dilation are only apparent in a specific inertial reference frame. When the object in motion stops, these effects disappear.
Matis
Greetings from Croatia :)
It may seem like a 100 times told story but it's not...
Let us imagine that we have a rocket with length 50 m when at rest. The rocket goes on a trip and accelerates to the speed near c. Observer from Earth "measure" it's length as 48m (illustrative value),that is for the observer, rocket's length is contracted. But no matter what "exhibitions" rocket preforms at speed close to c and regardless of that length contraction, when rocket returns to Earth it will be of course 50 meters long and not 48.
At the same time when length contraction occurs, observer from Earth "sees" that rocket clock is going slower than our clock and we also see all passenger's biological processes on that rocket as slowed down. Now, SR says that time for the man in that rocket goes normally and also observer's time on Earth goes normally...so my question is, what causes different time accumulation on rocket's clock and on Earth's clock when these two clocks are compared after rocket returns on Earth ? (clocks are synchronized before the trip, and if there are any internal or external mechanical influences that can affect on process of generating seconds, they are subtracted from the result time)
Upper question also imply - What is so special in speed of light that when rocket travels at speed close to c, traveling at that speed causes different biological age of two people (observer on Earth and man in the rocket born on the same date when they are reunited after rocket returns to Earth) ?
This is the point - if after rocket's return length remains the same regardless of our measurement of it's smaller length when it was traveling at speed close to c , what is the cause of different time accumulation and different biological age, that is, if the length remains the same, why the time accumulated on almost ideal clocks is also not the same but different?
For now I still believe that time dilation and length contraction are real and at the same time apparent phenomena, that is, motion is relative and every frame of reference is equal so what one observes/measure is the true value but at the same time after rocket from the upper story comes back in our frame of reference time dilation and length contraction become apparent because length is the same as before the trip and the time should also be the same on both clocks, but maybe you can explain me why I'm wrong.
I still haven't found a proper answer to these question/s. Thank you!
The proper answer is very simple: pick an Inertial Reference Frame. Any object/clock/observer moving in that frame is length contracted along the direction of motion and experiences Time Dilation as a function of the speed. The faster it goes, the more the Length Contraction and the more the Time Dilation. When the object/clock/observer stops moving, the Length Contraction and Time Dilation goes away. If the traveler just had a metronome with him, it would tick slower while traveling and then come back to the same tick rate as the Earth's metronome, just like a ruler would only be contracted while traveling. The difference between a metronome and a clock is that the clock has a way to count the ticks of its built-in metronome but a ruler does not have a corresponding accumulator for any length it is marking out during the trip.
So if you pick the IRF in which the Earth remains stationary, them only the traveler's clock will suffer Time Dilation and since it is accumulating those slow ticks, when it gets back, it will have accumulated fewer ticks than the Earth's clock.
Now isn't that so very simple you could explain it to a child?
hm...
But metronome ticks slower only for observer on Earth and not for the guy in the rocket, for him his metronome ticks normally. So traveler's clock is accumulating normal "ticks", we only see them as longer here on Earth.
And again, if regardless of the length contraction (which is also function of speed) length after arrival of the rocket doesn't change, why the time should change ?
I'm still not convinced that after this trip ideal clocks will show different time accumulated and that traveler will be younger than the observer.
As I've said in my first post - I believe that time dilation and length contraction are real and at the same time apparent phenomena, that is, motion is relative and every frame of reference is equal to other so what one observes/measure is the true value but at the same time after rocket comes back in our frame of reference time dilation and length contraction become apparent because there will be no difference in length before the trip and after the arrival and also I don't see a reason for different time accumulation if length remains the same..."
Matis said:
hm...
I said you can pick any IRF. Do you realize that if you picked a different IRF where the speed of the Earth is not zero, then the Earth's clock would be subject to Time Dilation and Length Contraction. Isn't it obvious that since we can pick any IRF, observers can never be aware of Time Dilation or Length Contraction, can they? And yet you twice said that they are both apparent. They are never apparent. Think about this. If you have a ruler that is Length Contracted but your foot is also Length Contracted, then how would it be apparent? Same thing with your clock. If your clock ticks slower and your heart beats slower, how would it ever be apparent? So get the idea out of your head that Length Contraction and Time Dilation are something that anyone can see or measure, OK? Everything always seems normal to all observers, OK?
Now that you know that, isn't it also obvious that in the IRF in which the Earth is at rest, the Earth's clocks will never be Time Dilated while the traveler's clock and the traveler are Time Dilated during the entire trip? Since the traveler's clock ticks slower and the Earth clock does not, when the traveler returns, his clock will have accumulated less time than the Earth's clock. But when the traveler comes to rest, his clock will start ticking at the same rate as the Earth's clock. That doesn't make the time on his clock suddenly go to a different time, does it? Please, tell me what is so hard to understand about this?
The different times displayed by the clocks are a trivial prediction of SR. But the part of SR that's used to make this prediction is really just an assumption about the numbers displayed by a clock that should be thought of as part of the definition of SR. So it seems that what you're really asking is why SR is a good theory. The only thing that can answer that is a better theory. Unfortunately, the only better theory is GR, and its definition includes the exact same assumption, so it can't tell us why SR is right about this particular thing.
Fredrik said:
If a clock displays t at one event and t' at another, then the proper time of the part of the clock's world line from the former event to the latter event is t'-t.
The prediction follows from this statement and the purely mathematical definition of the term "proper time".
Matis said:
...if the length remains the same, why the time accumulated on almost ideal clocks is also not the same but different?
This seems a bit illogical. It would have been weird if the clock's ticking rate had not been returned to normal when a meter stick is returned to normal. But the clock will of course display a smaller number if its ticking rate was lower during the trip.
However, the interpretation that its ticking rate was actually lower isn't the simplest one. It's kind of an old-fashioned interpretation that we don't need. The straightforward interpretation of SR is that the clock continued to work the way it always does, and that there's simply "less time" to be accumulated along the path through spacetime that describes the rocket's motion.
Can you correct me...
When the rocket is traveling at the constant speed of 0,89c relative to the Earth, the traveler would see everything on the Earth as slowed down and observer on the Earth would see everything on the rocket as slowed down (Galilean relativity principle) ?
At the same time the traveler's clock goes normally for him and the observer's clock goes normally for him, right ?
When we apply acceleration, this Galilean symmetry goes away and than we are sure that the clock on the rocket will count less time because it needed to accelerate first and then decelerate. From GR we know that the acceleration is equal to the gravity and when the clock is influenced by gravity it will go slower, right?
I've totally overlooked this sentence from your first post : "The difference between a metronome and a clock is that the clock has a way to count the ticks of its built-in metronome but a ruler does not have a corresponding accumulator for any length it is marking out during the trip." This sentence clarifies a lot.
@Fredrik
Thank you for your answer :)
It depends on the relative direction. If two inertial observers are traveling towards each other, they each see the other ones clock sped up, not slowed down. When they pass, they see each others clock slowed down.
Right.
In some special cases of acceleration, you can jump to some conclusions based on symmetry but in all cases, what I described in my first post always works correctly. What if both observers accelerate? Wouldn't you like to know how to handle that situation?
Matis said:
From GR we know that the acceleration is equal to the gravity and when the clock is influenced by gravity it will go slower, right?.
There is no simple answer involving gravity like there is when we ignore gravity which is what we do in Special Relativity. You need to understand SR before you attempt GR.
Well I'm glad you went back and reread my earlier post. I read all of your posts very carefully before I respond and I assume you do the same.
ghwellsjr said:
You must not be a child. A child would have understood what I said.
this is an unbelievably condescending and arrogant response. besides being wrong and ignoring the issue. ghwellsjr didn't explain anything and is just ignoring the whole premise of the Twin Paradox.
probably this wikipedia article will explain it better than either of us and more accurately than ghw. http://en.wikipedia.org/wiki/Twin_paradox#Resolution_of_the_paradox_in_special_relativity
essentially the twin that is accelerated has it different than the twin that is not accelerated. the accelerated twin changes inertial frames of reference and has to do some accounting of time each time he switches from one inertial frame to another.
This is my perception that I've had in my mind and that was "killing" me:
Metronome ticks slower only for the observer on the Earth and not for the guy in the rocket, for him his metronome ticks normally. Traveler's clock is always accumulating normal "ticks", we only see them as longer here on the Earth but on that rocket ticks are always the same, not stretched or contracted. If the traveler's clock is always accumulating normal ticks that always have the same rate and which are only seen as longer from the Earth, from where does different accumulation of time comes if the clock on the Earth never changes it's rhythm nor does the clock on the rocket ? That is, if the traveler's clock has always been ticking normally for him and when he comes back to the Earth, observer on the Earth also sees traveler's clock ticking normally, I've asked my self how there can be different time accumulated.
Now I see that I've got it all wrong.
Related to Different time accumulated on clocks
1. How do different time zones affect the time accumulated on clocks?
Time zones are geographical regions that have a uniform standard time for legal, commercial, and social purposes. This means that clocks in different time zones will show different times. For example, if it is 12 PM in New York, it will be 9 AM in Los Angeles due to the three-hour time difference. Therefore, the time accumulated on clocks will vary depending on the time zone they are set to.
2. Why do some clocks show a different time than others?
Clocks can show different times due to several reasons. One of the main reasons is that they may be set to different time zones. Other factors that can affect the time displayed on clocks include daylight saving time, power outages, and manual adjustments made by the user. Additionally, if a clock is not synchronized with a reliable time source, it may show a slightly different time than other clocks.
3. Can the time accumulated on a clock be inaccurate?
Yes, the time accumulated on clocks can be inaccurate for various reasons. One common reason is that clocks may lose or gain time over a period of use due to internal mechanisms. Another reason is that the clock may not be synchronized with a reliable time source, causing it to show a slightly different time. It is important to regularly check and adjust clocks to ensure they are displaying the correct time.
4. How do atomic clocks maintain accurate time?
Atomic clocks are the most accurate timekeeping devices currently available. They use the vibration of atoms to measure time, rather than mechanical parts like traditional clocks. The atoms used in atomic clocks are usually cesium or rubidium, and they vibrate at a constant rate, making them highly accurate. These clocks are also regularly synchronized with a master clock to maintain precise timekeeping.
5. What is the purpose of having different time zones?
The purpose of having different time zones is to coordinate time across different regions of the world. Before the establishment of time zones, each location would keep its own local time, based on the position of the sun. This made it difficult to coordinate activities and schedules between different regions. Time zones were created to standardize time, making it easier to communicate and schedule events across long distances.
