Different types of differential geometry?
In summary: Differential geometry is the study of shapes that vary with respect to a few parameters, like the height of a person, the curvature of a catenary, or the displacement of an object in space. Differential geometry is divided into two main branches: classical and modern. Classical differential geometry of surfaces is presented only using calculus in three space. The ideas of manifold,tensors,metrics are unnecessary. Modern books do treat surfaces in 3 space using these ideas. Compare Struik's book on classical differential geometry with Singer and Thorpe's book to see the difference in approach.
dyn
773
61
I am planning on taking a course in differential geometry. I have looked at the notes and they cover - differential forms , pull-backs , tangent vectors , manifolds , Stokes' theorem , tensors , metrics , Lie derivatives and groups and killing vectors. I have a book called Elementary Differential Geometry by Pressley but it contains none of the above subjects apart from tangent vectors. So my question is ; are there different types of differential geometry and what is the type called that I am looking at.
Everything you listed would be under the umbrella of differential geometry, with Lie groups obviously in addition involving group theory and not just differential geometry. In addition, those subjects form basically the core of differential geometry (except maybe the differential forms and the Lie groups stuff which are a little bit more advanced). If your book mentions none of those subjects...I would find it very hard to believe its a book on differential geometry! Perhaps the topics are covered but the chapters are named differently for whatever reason?
I looked in the index and none of those areas are mentioned except for tangent vectors whereas I looked in the index of Geometrical Methods by Schutz and they are all included.
That's very odd indeed! I don't know this book by Pressley though so I can't really make any concrete comments about it. All I can say is that differential geometry usually starts off with manifolds and their definition, proceed to tangent vectors and tangent spaces, one forms and cotangent spaces, and finally tensors, Lie derivatives and flows.
And then depending on how much time the student has, one usually then sees more advanced topics like differential forms, volume elements, integration on manifolds, Stoke's theorem, affine connections, Riemannian and Pseudo-Riemannian manifolds with metric.
Thanks. Maybe the difference is that the Pressley book appears to be more on the "pure" side while the notes and the Schutz book come from the mathematical physics side of things.
Can you maybe list some major topics that Pressley's book does mention?
differential geometry is about curvature. see if that appears in the index.
I havn't studied differential geometry before so maybe things have different names but in the index of his book there is no mention of differential forms , pull -backs , manifolds , Stokes' theorem , tensors , metrics , Lie derivatives or killing vectors.
Yes curvature is in the index. Curvature of a catenary , curve , helix , asteroid and surface
I don't know this book you have either, but what comes to my mind is that it might be about stuff like surfaces and curves in higher dimensional Euclidean spaces. One can see curved surface as being drowned in three dimensional Euclidean space. That is old fashioned approach to differential geometry. If the surface alone is only thing that is really intersting to us then we want to forget about surrounding space and study properties of the surface alone. That is made precise by notion of a manifold. This approach is somewhat more abstract, but way more powerful.
But note that much of Riemannian geometry has to see with curvature in higher dimensions, i.e., dimensions 3-and-higher, where you need to bring in tensors and other tools, because there are many more directions to consider. AFAIK, the classical d.g. deals with curves and surfaces, and the more modern stuff deals with manifolds in general ; 3- and higher dimensional manifolds.
Looks like my Pressley book only deals with 3-D space so maybe doesn't need to use manifolds and differential forms etc. But my notes are concerned with mathematical physics so needs higher dimensions and thus needs manifolds etc.
In my opinion, it's better to start with a book like that because it's more down to Earth and you see where all the more modern concepts come from. So, don't get hung up on the fact that you "need" higher dimensions and manifolds right off the bat. You can understand all that stuff much better if you know curves and surfaces in R^3.
Related to Different types of differential geometry?
1. What is differential geometry?
Differential geometry is a branch of mathematics that studies the properties of curves, surfaces, and other geometric objects using calculus and other mathematical tools. It has applications in various fields such as physics, engineering, and computer graphics.
2. What are the different types of differential geometry?
There are several types of differential geometry, including Riemannian geometry, symplectic geometry, and complex geometry. Riemannian geometry studies smooth, curved spaces, while symplectic geometry focuses on symplectic manifolds, which are mathematical objects that describe physical systems with conserved quantities. Complex geometry deals with complex manifolds, which are spaces that can be described using complex numbers.
3. What is the difference between classical and modern differential geometry?
Classical differential geometry refers to the study of curves and surfaces using methods from calculus and classical geometry, while modern differential geometry uses more advanced mathematical tools, such as differential forms and tensor calculus, to study higher-dimensional manifolds and abstract geometric objects.
4. What are some real-world applications of differential geometry?
Differential geometry has many practical applications, including in physics, where it is used to study the curvature of spacetime in general relativity, and in computer graphics, where it is used to model and manipulate 3D objects. It is also used in engineering to optimize shapes for aerodynamics and in robotics to plan efficient paths for robots.
5. How does differential geometry relate to other branches of mathematics?
Differential geometry has connections to many other areas of mathematics, such as topology, algebraic geometry, and Lie theory. It uses tools from these fields to study geometric objects and also provides insights into their underlying structure. Additionally, many concepts and techniques from differential geometry are used in other areas of mathematics, such as in the study of partial differential equations and optimization problems.
  • Differential Geometry
