curious_ocean
- 36
- 7
Hi PF,
I am teaching an introductory college level Earth Science course and have few questions about the different types of volcanoes.
I understand that the type of magma largely dictates the volcano type, where felsic (rhyolitic/granitic) magma has a higher silica and gas content than (basaltic) mafic magma. The higher silica content means that the viscosity of felsic magma is higher relative to mafic magma. Additionally, the temperatures at which felsic magma tends to erupt is lower than basaltic, further reducing felsic magma viscosity relative to mafic magma.
Q1: Why does felsic magma erupt at a lower temperature than mafic? (My guess is that this is also due to the higher viscosity?)
Hot mafic magma more readily (gently) releases gases and basaltic lava flows faster and farther before cooling, developing low slope shield volcanos.
In comparison the felsic magma tends to create some of the most dangerous explosive pyroclastic flows, due to the high viscosity and gas content of the magma.
Due to the higher viscosity (and cooler temperatures?) the flows do not travel as far before they cool, creating steeper sloped volcanoes.
Q2: Is there a name for this type of felsic magma induced volcano? Or do these not really exist?
Andesitic magma, which has a composition somewhere in between felsic and mafic magma, can create composite (/strato) volcanos, which are composed of alternating layers of cooled lava flows and pyroclastic flows.
From what I understand, mafic magma can be created in 2 ways. One way is decompression melting of the mantle, where hot rock rises so quickly that the drop in pressure causes it to melt. This can happen at divergent plate boundaries (spreading centers) or a mantle plumes (hot spots). The other way is by flux melting which happens at subduction zones where the water that is being subducted causes melting of the mantle.
I think that felsic magma is created by additionally melting continental crust. For example, at convergent plate boundaries where oceanic lithosphere runs into continental lithosphere, the mafic magma created by flux melting at the subduction zone rises until it meets the continental crust. The continental plate is less dense than this magma, so the magma pools under the continental crust until it becomes so hot that it can further melt through the crust. This is where it picks up the "extra" silica and gas content.
By this logic shield volcanoes would tend to develop at mid-ocean ridges, oceanic hot-spots, and subduction zones where 2 oceanic plate edges are colliding.
Stratovolcanoes would tend to develop at subduction zones where oceanic and continental plate edges are colliding.
This seems somewhat consistent with what I have read.
Q3: Would stratovolcanoes also tend to occur at continental hot spots, and early-stage continental rift areas, since magma would be passing through continental rocks there?
Q4: Are cinder cone volcanoes associated with a particular type of magma?
Thank you for your help!
PS - Please correct any of my mis-statements. I have a physics and oceanography background, so I have a lot of learning to do for the modules of this Earth Science class that are outside of my expertise.
