Differentiability in higher dimensions
In summary, the given function is differentiable at (0,0) if the two subfunctions are equal at (0,0). To show this, the definition of differentiability is used, which involves calculating the partial derivatives for both subfunctions and showing that they are equal at (0,0). The Jacobian matrix is not applicable in this case since the function is a real-valued function of two variables. The differential of the function can be found in the textbook and it involves using the two partial derivatives to calculate the differential Df(0,0).
RiotRick
42
Examine if the function is differentiable in (0,0)##\in \mathbb{R}^2##? If yes, calculate the differential Df(0,0).
##f(x,y) = x + y## if x > 0 and ##f(x,y) =x+e^{-x^2}*y## if ##x \leq 0 ## (it's one function)
##lim_{h \rightarrow 0} \frac{||f(x_0+h)-f(x_0)-J(h)||}{||h||}=0##
I'm not familiar with two subfunctions in one function.
So my plan is: I show the definition for both subfunctions if x> and <0 and then i show that both are equal at 0.
I calculated the partial derivative for ##x \leq 0##:
##\frac{f(0+h,0)-f(0,0)}{h} = \frac{h+e^{-h^2}*0}{h}= 1##
##\frac{f(0,0+h)-f(0,0)}{h} = \frac{0+e^{0}*h}{h}= 1##
so J = (1,1)
##\frac{f(0+x,0+y)-f(0,0)-(1,1)*(x,y)^T}{\sqrt{x^2+y^2}}=\frac{x+e^{-x^2}*y-0-(x+y)}{\sqrt{x^2+y^2}}##
now if x is less 0 we can simplify to:
##\frac{y*e^{x^2}-y)}{\sqrt{x^2+y^2}}##
##\frac{r*sin(\theta)*e^{(r*cos(\theta))^2}-r*sin(\theta))}{r}##
##\frac{sin(\theta)*e^{(r*cos(\theta))^2}-sin(\theta))}{1}##
if r approaches 0 then
##\frac{sin(\theta)*e^{0}-sin(\theta))}{1}=\frac{sin(\theta)*1-sin(\theta))}{1}=\frac{0}{1}=0##
Does this work so far? Is my idea okay and can I proceed this way for x>0?
This is somewhat difficult to follow. The goal here is to find the differential Df at (0, 0). To do that, you need both first partials, and for each partial you need to look at two limits. One limit is as ##h \to 0^+##, and the other is as ##h \to 0^-##.
The work you show above appears to be looking at ##\frac{\partial f}{\partial x}## and ##\frac{\partial f}{\partial y}##, but doesn't take into account that the function f is defined in a piecewise fashion. For each of the partials that I wrote to exist, you have to show that the two one-sided limits exist and are equal.
RiotRick said:
so J = (1,1)
See my comment above.
As already noted, the goal here is to find Df(0, 0). Do you know the formula for the differential of a function? For a two-variable function, it should involve dx and dy.
Mark44 said:
This is somewhat difficult to follow. The goal here is to find the differential Df at (0, 0). To do that, you need both first partials, and for each partial you need to look at two limits. One limit is as h→0+h \to 0^+, and the other is as h→0−h \to 0^-.
I'm now quite buffled that my approach with the definition is "hard to follow". First I need to show that the function is differentiable and then calculate Df. I use only the definition of differentiability. With the first steps I calculate my Jacobian Matrix to use it for the J(h). I don't know how to use your approach since "h" disappears anyway.
Yes, that's the right idea, but you're not going about it the right way. Below are some of the things you wrote in a previous post, plus my comments.
1. "The partial derivative" makes no sense. For your function there are two partial derivatives -- one with respect to x and the other with respect to y.
2. Since your function is defined piecewise, each equation above needs to show what the limit is as h approaches zero from below (x <= 0) as well as from above (x > 0). If you did that, you didn't show it
The definition you used is for a function that is defined in only one way. Your function has different formulas, depending on whether x <= 0 or x > 0.
so J = (1,1)
This doesn't make sense to me. For one thing, (1, 1) is a vector, not a matrix. A Jacobian is always a square matrix. The Jacobian matrix applies to vector-valued functions, such as a function that maps ##\mathbb R^2## to ##\mathbb R^2##. Your function is a map from ##\mathbb R^2## to ##\mathbb R##. IOW, it's a real-valued function of two variables.
I don't know where you got this formula, but it definitely doesn't apply to the function at hand in this problem.
Let me ask again, for a function of two variables f(x, y), how is the differential of f (Df) defined? You should be able to find it in your textbook, probably in the same section as the problem you're working on. If you can't find it in your book, look up differential on the internet. The context here is the differential of a function of several variables.
In my notes and in wikipedia:
A function with more than 1 variable is differentiable if:
But this isn't what you have. From the wikipedia article on Jacobian matrix and determinant,
https://en.wikipedia.org/wiki/Jacobian_matrix_and_determinant said:
In vector calculus, the Jacobian matrix is the matrix of all first-order partial derivatives of a vector-valued function.
The notation as used in the wikipedia article with f in bold -- f -- means that f is a vector-valued function. That is ***NOT*** what you have in this problem. For a given point ##(x, y) \in \mathbb R^2##, there is a single value of f(x, y).
An example of a vector-valued function of one variable is ##\textbf r(t) = <f_1(t), f_2(t), f_3(t)>##.
okay I see. I got this wrong about the Matrix.
##lim_{h \rightarrow 0} \frac{||f(x_0+h)-f(x_0)-A(x-x_0)||}{||h||}=0## where A is my mxn matrix of the linear mapping of the partial derivatives. So A = (1,1) in my example
Again, no. There are several things wrong with your definition above.
1. The function in this problem has two arguments, not one.
2. For your function, you need to examine both one-sided limits of each partial derivative -- four limits in all.
3. Your expression ##A(x - x_0)## makes no sense in this context, since A is a vector and ##f(x_0 + h), f(x_0)## and ##(x - x_0)## are all scalars (numbers). You can't mix them like this.
You're making this problem way more complicated than it needs to be. Since you don't seem to be able to find the definition of the differential of a function, take a look here: https://en.wikipedia.org/wiki/Differential_of_a_function, in the section titled Differentials in several variables.
The first function should be easy enough to find the differential for, since it's a linear transformation. Once you have the expression for the differential, and if you want to find the matrix for this linear transformation, try applying the linear transformation to a column vector of two variables, and figuring out what two entries should go into the two entries of the 2 x 1 matrix based on that expression. Meanwhile, for the second problem, I would indeed look at the matrix of partial derivatives: it should be a 1 x 2 matrix consisting of the partial with respect to ##x## and the partial with respect to ##y##.
There is only one function -- it's defined in a piecewise fashion.
... the OP can evaluate it at the point (0, 0). That's all the problem asks for.
Eclair_de_XII said:
, and if you want to find the matrix for this linear transformation, try applying the linear transformation to a column vector of two variables, and figuring out what two entries should go into the two entries of the 2 x 1 matrix based on that expression. Meanwhile, for the second problem, I would indeed look at the matrix of partial derivatives: it should be a 1 x 2 matrix consisting of the partial with respect to x and the partial with respect to y.
There is no second problem. The problem as given is a fairly straightforward one, and doesn't require the use of matrices, square or otherwise, or Jacobians. The definition of the differential of a function of two variables is shown in all calculus textbooks, as well as in the wikipedia page I linked to.
But isn't that exactly what I tried with:
so J = (1,1)
so J = (1,1)
This isn't even close to what you're trying to get.
The answer should look like this: ##Df(0, 0) = \text{something} \cdot dx + \text{something else} \cdot dy##
The first something is ##\frac{\partial f}{\partial x}(0, 0)## and the other something is ##\frac{\partial f}{\partial y}(0, 0)##.
You're making this much more complicated than it needs to be with the Jacobian business and conversion to polar form.
Related to Differentiability in higher dimensions
1. What is differentiability in higher dimensions?
Differentiability in higher dimensions refers to the concept of how a function changes as the number of independent variables increases. It is a measure of the smoothness of a function and is closely related to the slope or rate of change of the function at a given point.
2. How is differentiability in higher dimensions different from differentiability in one dimension?
In one dimension, a function is considered differentiable if it has a well-defined derivative at every point. In higher dimensions, a function is considered differentiable if it has well-defined partial derivatives with respect to each independent variable at every point.
3. What is a partial derivative?
A partial derivative is the rate of change of a function with respect to one of its independent variables, while holding all other variables constant. It measures how much the function changes in a specific direction.
4. How is differentiability in higher dimensions related to continuity?
A function is differentiable at a point if and only if it is continuous at that point. This means that a function must be continuous in order to be differentiable in higher dimensions.
5. What are the practical applications of differentiability in higher dimensions?
Differentiability in higher dimensions is used in many fields, including physics, engineering, and economics. It is essential for understanding the behavior of complex systems and for optimizing functions with multiple variables. It also plays a crucial role in multivariable calculus and in the development of advanced mathematical models.
