MHB Differentiability of a Complex Function
shen07
$$ f:\mathbb{C}\rightarrow\mathbb{C}
f(z)=\left\{\begin{array} \frac{(\bar{z})^2}/ {z} \quad z\neq0 \\
0 \quad z=0
\end{array}
\right.$$
Show that f is differentiable at z=0, but the Cauchy Riemann Equations hold at z=0.
Well i have tried to start the first part but i am stuck, could you please help me out.
WORKING:
f is diff at z=0
if $$ \lim_{z \to 0} \frac{f(z)-f(0)}{z-0}\; exists\\
\lim_{z\to0}\frac{ \frac{(\bar{z})^2}{z}-0}{z-0}=
\lim_{z\to0}\frac{(\bar{z})^2}{z^2}
Now we get indeterminate form in the limit but how can we differentiate $$\bar{z}$$
0 \quad z=0
\end{array}
\right.$$
Show that f is not differentiable at z=0, but the Cauchy Riemann Equations hold at z=0.
WORKING:
f is diff at z=0
There is an important word missing from the statement of the problem. The result should say that f is not differentiable at 0, despite satisfying the C–R equations at that point.
You have correctly shown that the condition for f to be differentiable at 0 is that $$ \lim_{z \to 0} \frac{f(z)-f(0)}{z-0} = \lim_{z\to0}\frac{(\bar{z})^2}{z^2}$$ should exist. To see that the limit does not in fact exist, use the polar form $z = re^{i\theta}$, so that $\bar{z} = re^{-i\theta}$. You should find that the limit as $r\to0$ varies for different values of $\theta$, and is thus not uniquely defined.
To see that the C–R equations hold at 0, write $z=x+iy$, $\bar{z} = x-iy$ and find the partial derivatives of $f(x,y)$ at the origin.
Well you are right i just miss the not,
now using $z = re^{i\theta}$
$$ \lim_{z\to0}\frac{(\bar{z})^2}{z^2}=\lim_{r\to0} \frac{(re^{-i\theta})^2}{(re^{i\theta})^2}
now the r's cancel out, i didn't understand what you tried to tell me, Could you Clarify Please.
If $\theta = 0$ then
$\displaystyle \frac{e^{-i2\theta}}{e^{i2\theta}} = 1$
If $\theta = \frac{\pi}{4}$ then
$\displaystyle \frac{e^{-i2\theta}}{e^{i2\theta}} = \frac{1}{e^{i\pi}} = -1$.
These values are independent of $r$ (as you noted, the $r$'s cancel).
What is your conclusion?
Since $\theta$ varies, the function is not continuous at z=0 hence Not Differentiable. Right?
MultiVariable Function? is it?
If the limit DID exist, we should be able to choose $r > 0$ such that on a disk centered at the origin with radius $r$, the quantity:
$\displaystyle \frac{(re^{-i\theta})^2}{(re^{i\theta})^2}$ is always within $\epsilon$ of the limit, for ANY $\epsilon > 0$.
What happens if we choose $0 < \epsilon < 1$? Will ANY $r > 0$ work?
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
